20" Razor's and hubcentric rings
Old Apr 8, 2008 | 05:23 PM
Robbieg's Avatar
Does anyone know what size hubcentric rings are needed for an '07 GT with 20" Razors. If it matters they are the 24mm offset gunmetal. I thought someone posted it before but Ive searched and searched and cant find anything.
Old Apr 8, 2008 | 05:47 PM
Deric's Avatar
Contact American Racing or TireRack and they can tell you if no one else answers.
Old Apr 8, 2008 | 06:15 PM
sorry I can't help. Why do you need them? What do they do?
Old Apr 8, 2008 | 06:38 PM
here I go
http://images.google.com/imgres?imgu...%3Den%26sa%3DG
long link
Old Apr 8, 2008 | 07:16 PM
Poco's Avatar
Check this link from Tire Rack.Scroll down to "specific wheel hardware",click on that. The 4 hubcentric centering rings are sent with the set.Call Tire rack about these centering rings. They should have the info you seek.I did check and they come with 24 and 40mm offsets. Pat
http://www.tirerack.com/wheels/Wheel...oModClar=Coupe
Old Apr 9, 2008 | 07:02 AM
The place I got my rims from sent me some from Ca. They should be here today. If I can tell where they came from and have a part number on them I will post the info
Old Apr 9, 2008 | 08:19 AM
nm3's Avatar
nm3
Do you know what the size of the rings are (id and od)? I think I need to buy them too.....
Old Apr 10, 2008 | 05:24 AM
nm3's Avatar
nm3
I ordered a set from Tire Rack. Was just under $20 for all 4 shipped. I should have them today.
Old Apr 11, 2008 | 02:39 PM
finaly recieved mine
american racing HRM727030
72.62/70.30 metal hubring
they fit nice
Old Apr 11, 2008 | 07:34 PM
nm3's Avatar
nm3
I put mine on today, but didn't test drive due to precipitation. Mine were plastic though. Got them from Tire Rack.
Old Apr 12, 2008 | 05:43 AM
mine didn't help. I guess I will have the tires rebalanced
Old Apr 12, 2008 | 07:53 AM
nm3's Avatar
nm3
Not what I wanted to hear.....I hope they work on mine. I'll let you know when I drive it again.
Old Apr 12, 2008 | 01:33 PM
seabiscuit's Avatar
Can you please give a link where you got them?
Old Apr 12, 2008 | 04:11 PM
nm3's Avatar
nm3
Called Tire Rack and told him what wheels I had and fixed me up with the hubcentric rings from American Racing. I couldn't find them on the website either.
On my bill the part number is HR727030 qty 4 at $3 each.
Hope this helps.
nm3 said he got them from www.thetirerack.com
I just checked and can't find them listed any where I guess you will have to call them.
I also looked on www.americanracing.com and can't find them listed there either.
Old Apr 13, 2008 | 01:25 AM
seabiscuit's Avatar
Thanks for info. By the way NM3 how your Vredestein Ultrac Sessanta tires go? Are you happy from them?
Old Apr 13, 2008 | 01:35 AM
seabiscuit's Avatar
Hope this helps.
Can you confirm they are the same dimater on link below?
http://www.sfxperformance.com/parts/MRLHR727030.htm
BTW
1/ What tire pressure you are using for 255/35/20 - 32psi like on stock tires?
2/ What torque in NM you are using to your alloy Razors?
Old Apr 13, 2008 | 08:31 AM
nm3's Avatar
nm3
Part number looks correct to me. Seems as though the put MRL in front of the part number I have. MRL would stand for MR. Lugnut.
I am Running stock tire pressure and torqued my lug nuts to 100 ft-lbs with my clicker torque wrench. Not sure what the NM conversion is though.
I still have a very minor vibration at highway speeds. The hubcentric rings have seemed to help some.
Old Aug 11, 2008 | 09:39 AM
Phorty's Avatar
Reviving an old thread...
I had the same issue with vibrations with my Wedsports wheels. I bought some of the rings TireRack sells for this set-up. They fit tightly in the wheels but were pretty loose around the hub. Is this normal? They helped vibrations but it's still not perfect.
Old Aug 11, 2008 | 12:54 PM
Robbieg's Avatar
They should be nice and tight both on the wheel and on the hub, thats what gives it the ability to be perfectly centered.
