18" Tire Sizes
according to Tire Rack - the largest width you can use on an 8" wheel is 255.
The proper tire for that sized wheel is 255/45/18 - it puts the spedo off like 0.4% or something - which is like less than 0.5 mph @ 60.
Originally posted by budgreen3564@October 7, 2005, 9:14 AM
i called them and got the same info. i'd like to go 275
:nono: Most 275's fit correctly on a 9" wide wheel. As they are a 10" tire. Manufactures widths vary and most are too wide for a 8" wheel to perform safely.
Check out this thread...
http://forums.bradbarnett.net/index.php?showtopic=34508
It is about "aftermarket" Ford rims - It shows some 18" Bullits that are 8.5" wide - plus some others. I am not sure of their availability as of right now. But if you have yet to get your car - you may want to wait a tad bit more and try to "work" these wheels into your deal for your car. That's what I am thinking about doing. I'd like that little extra width. I think your sidewalls would like it too.
Originally posted by Infinity@October 7, 2005, 12:54 PM
I was told the fanblades are 8.5" wide.
Originally posted by budgreen3564@October 7, 2005, 5:48 AM
what is the largest tire i can put on the '06 18X8 wheel?
http://www.bfgoodrichtires.com/asset...rce_ta_kdw.pdf
fits on 8-10 inch rims
+ lots of sidewall to fill the wheel wells
don't know if it will actually fit inside the wheel wells... but if you try be sure to let us know
also, a 275/50 will fit on an 8 inch wheel, too, if you can find that size. Nitto has one for a 17 inch wheel.
http://www.nittotire.com/popup_450_sizes.asp
Originally posted by nonsensez9+November 17, 2005, 9:13 PM--><div class='quotetop'>QUOTE(nonsensez9 @ November 17, 2005, 9:13 PM)</div><div class='quotemain'>go for the 285/60/18 BFG GForce TA kdw
[/b]
[/b]
Wow... 285/60-18 is a frikkin huge tire!! It's about 31.5" tall... yikes. I love big fat tires more than most people on these boards, but I doubt that would be a good choice for these cars. I also don't see how in the heck it would fit right on a 8" wheel. Of course, that's just my opinion.
<!--QuoteBegin-nonsensez9@November 17, 2005, 9:13 PM
also, a 275/50 will fit on an 8 inch wheel, too, if you can find that size. Nitto has one for a 17 inch wheel. [/quote]
When I had my 275/50s installed the first time, the ******** at the tire store mounted them on my stock 8" wheels instead of the new 17x9's I brought for them to use. And frankly, 275/50s on an 8" wheel looked scary. The way the bead was pulled way in did not look safe to drive on.
Do you have any idea on how far off the speedo would be with a 60 series tire? Also I am pretty sure it would rub. My 285/40's come pretty close as it is. You should go as close to stock when you can, and that is the 285/40's.
Just keep in mind that the 285/60 has a minimum rim size of 8". That would make the sidewalls buldge just a bit, but I sure don't think they would look good on the car.
I have seen people put 275's on 8" wide wheels and haven't heard of any problems... but I would still go no higher than 255's, just to be safe. You won't like the buldge in the sidewall anyway with 275's.
the 18 inch factory rims are 8.5 inches. there are companys selling 275/40/18 on the 8.5 rim with toyo s1 tires. sean hyland motorsports is one. here is the link
http://www.seanhylandmotorsport.com/online...ec6a3512c497f83
Not sure what I am going to get yet. polished 18x8.5 on the car, on the way. should be here anyday. well see when i get it I guess.
JonathonK
7/27/15 07:35 PM
