Aftermarket 2005+ Mustangs Discuss the Offerings from Roush, Saleen, Steeda, Shinoda, and Others
Whipple Over Eaton
Old Mar 23, 2005 | 02:51 PM
vld's Avatar
vld
Thumbs up
Anybody know why?
Old Mar 23, 2005 | 02:59 PM
1 COBRA's Avatar
Performance? Perhaps cost? Perhaps a little of both.
Old Mar 23, 2005 | 03:00 PM
Scothew's Avatar
Stubborn Bear
TMS Staff Retired
I think its both. Probably cost close to the same, with slightly better performance. Plus I believe whipple 'chargers acctually produce a tad less heat than an eaton.
Old Mar 23, 2005 | 03:05 PM
jsaylor's Avatar
Scothew is right. Twin Screws are a more efficient design than rootes blowers are. They generate less heat and they don't simply force air into the motor they actually compress they air too, which creates a denser air charge. More oxygen, bigger bang, more power.
A twin screw will also produce similar boost at far fewer rpms than will the older rootes, and even makes more hp at a given bar/lb of boost! They basically stomp on the older rootes design in every respect.
Old Mar 23, 2005 | 03:12 PM
vld's Avatar
vld
whipple has kits for the 3v 4.6 for 5600. thats a chunk of cash. that includes heat exchanger, reflash, etc though. course, then theres the internals...
Old Mar 23, 2005 | 03:14 PM
1 COBRA's Avatar
Originally posted by jsaylor@March 23, 2005, 5:08 PM
Scothew is right.
Scott is right?
[1 BULLITT fuming and foaming at the mouth]
Old Mar 23, 2005 | 04:03 PM
xlch59's Avatar
It will not be a twin screw because Lysholm can not make the twin scews fast enough. 10 preday for the twin vs 50 for the single screw
Old Mar 23, 2005 | 05:18 PM
S197Cobra's Avatar
Without a twin screw, there is little point in using a 5.4L -- the Eaton M112 would just choke it. And I think that even if your number is correct, a production order from Ford for 7500 superchargers would inspire Lysholm to figure out how to make the screws faster.
Dave
Old Mar 23, 2005 | 05:43 PM
Shelby Roadster's Avatar
Call up Whipple and ask them. It's a twin screw.
GT/CS Guy
Aug 13, 2015 07:54 PM
