Mustang GT-R Cconcept Technical Specifications
Body
Lightweight RPS body panels with carbon fiber hood, aero devices, instrument panel, interior door panels and floor heal pads
Engine – Ford Racing 5.0L "Cammer" V8
Configuration – V-8, aluminum block, aluminum four-valve cylinder heads, forged aluminum pistons
Bore x Stroke – 94 mm bore x 90.0 mm stroke
Displacement – 5.0 liters (302 cu in/4995 cc)
Compression ratio – 11.0:1
Horsepower – 440 @ 7000 rpm
Torque – 400 lb-ft @ 5500 rpm
Redline – 7,000 rpm
Valvetrain – Double overhead camshafts, four valves per cylinder
Intake valves – Two per cylinder, 38 mm
Exhaust valves – Two per cylinder, 32 mm
Throttle body – Twin 57 mm
Drivetrain
Transmission – Ford Racing/Tremec T-56 6-speed
Rear axle – Winters/Ford 9-inch design
Gear ratios –
1st – 2.97
2nd – 2.07
3rd – 1.43
4th – 1.00
5th – .80
6th – .62
Final drive – 4.56:1
Differential – Winter's race-spec rear differential
Clutch – Ford Racing "Cobra R" heavy-duty clutch/flywheel assembly
Driveshaft – Metal matrix composite aluminum custom driveshaft
Exhaust – Complete stainless steel race exhaust with Tri-Y design headers, crossover and side exit tips
Chassis and Suspension
Chassis – Fully reinforced fabrication
Suspension – Original production geometry with lightweight chrome-moly tube (aircraft quality) construction
Front – Reverse-L independent rigid strut tower brace with lightweight chrome-moly K-member and race-spec anti-sway bar with 1.25-inch box section
Rear – Three-link, solid axle with dynamic, fully adjustable shocks with remote reservoirs and coil-over springs, race-spec 1.25-inch panhard rod, and race-spec anti-sway bar
Brakes
Front – Brembo Racing 6-piston calipers and 14.3-inch rotors, 1.25-inch thickness
Rear – Brembo Racing 4-piston calipers and 13-inch rotors, 1.25-inch thickness
Wheels & Tires
Front –
Pirelli P275/35/20 racing slicks
20 x 10-inch, 5-spoke billet aluminum wheels
Rear –
Pirelli P315/30/20 racing slicks
20 x 11-inch, 5-spoke billet aluminum wheels
Redline – 7,000 rpm
Drivetrain
Gear ratios –
1st – 2.97
2nd – 2.07
3rd – 1.43
4th – 1.00
5th – .80
6th – .62
Brakes
Wheels & Tires
Front –
Rear –
GREAT info! Where did you get that? I know the price will be in the $40K range (see FoMoCo Press page, near the bottom of the release):
http://media.ford.com/newsroom/feature_dis...m?release=17442
I can't say I agree entirely. I was thinking a short-run Trans-am car, primarily for Ford sponsored teams, ya know, for promo purposes. But they could be doing a one-off to promote the new Mustang and their aftermarket parts. I guess we'll have to wait and see...
I think what they mean is that this is "a hint of what's to come" from Ford. And, with their mention of a 40 thousand car, I feel this is our next Cobra, just all dressed up for racing.
I Hope its not the next Cobra, Cobra guys are loving the ease of modifying the current Cobra. I think most would prefer it to come S/C from the factory. It would be nice in a Boss 302 version, but as i understand, is the Cammer, not emissions legal in the current configuration?
Just a GTO?
I can see this car whomping a lot more than that!
Then after its easy victory it can smoke up a C6 to warmup.
Originally posted by Twilightblu92@Apr. 5th, 2004, 4:57 PM
Yeah I'm pretty sure it could take some other cars:...M3
http://www.bmwusa.com/Joy/Motorsport/m3/
I think it would be a good race.
Going down the list, I'm wondering about the $40k-$45k price . If the GT is most likely gonna go for about $25,000.00...
Ok say you strip $15,000 of parts out of the GT, can the rest of that part list be had at $30,000-$35,000? Does that sound about right?
Originally posted by PaperTarget@Apr. 6th, 2004, 11:42 AM
Here's a better question. Has the 5.0L Cammer been certified for emissions in a vehicle yet?
I think we should forget the 5.0 Cammer. I'd look for something like the 6.4L V10. (which does have a chance of making production) with two cylinders chopped off. That gives you a 5.1L V8. Now, destroke for 5.0L. Still undersquare, and much more likley for production, IMHO. Give it five or six years and we will probably see it.
Originally posted by PaperTarget@Apr. 6th, 2004, 1:32 PM
I think a Boss will show up before then and I'm pretty sure it will be 5.0 to 5.4 liters in size.
I don't expect that there will be a factory Boss Mustang. We'll get a Shelby GT (perhaps called GT350) instead. It may well have a 5.4L, but a 5.0L is not likely IMHO.
