Will any strut tower braces clear the X-Charger on the 4.0L V6?
Old Jan 11, 2007 | 04:48 PM
Sniper308's Avatar
Just trying to plan ahead. Please let me know if anyone makes an STB that will clear the subject blower on our V6 engines?
Thanks.
Old Jan 11, 2007 | 11:12 PM
soitsav6's Avatar
the car that Doug installed the hi-po on last July had a stb, not sure of the brand, may be able to go back and find the post from last year and look at it.
Old Jan 14, 2007 | 09:05 PM
Torch_Vert's Avatar
The "X" sits about 1/2" to 3/4" lower than the stock manifold when installed. Any V6 brace should most likely fit. Some GT ones might too, but I haven't tested that theory.
I have a brace on mine, and I gained space under it when the "X" went in.
Old Jan 15, 2007 | 09:44 AM
Sniper308's Avatar
This is awfully encouraging, Paul, thanks. I hope David can get some more carbonfiber stock (and a "good" subcontractor). Previously, I'd been looking at the double-beam Steeda, but it's steel and David's is only four pounds and, with our V6 engine, you need to take advantage of lightweight things whenever you can.
Russ
oneeyedgiant
Nov 16, 2015 12:23 PM
RoushRS3
Sep 29, 2015 08:03 PM
AJ_Trevino15
Sep 28, 2015 07:51 AM
dohc97
Sep 24, 2015 01:52 AM
Sep 16, 2015 06:44 PM
