v6 with vibration under car
Old Jun 6, 2007 | 08:18 PM
dazeakamike's Avatar
I was wondering if anyone else with a v6 has a vibration under the car in park or neutral at idle. Mine happens when the car is warm (not idle warm-up but driving). Just got it back from dealer today (2 days they had it) and they are claiming that it is normal !?
Old Jun 6, 2007 | 11:04 PM
Zodiac's Avatar
I have crazy insane vibration from underneath the car. Pretty sure its related to the driveshaft. Very noisy too, especially w/ the hurst installed.
Old Jun 8, 2007 | 07:43 PM
ravenblack67's Avatar
There are multiple TSBs for this. Mine was fixed by adding a damper to the exhaust system per the TSB. Tell the dealer to check the TSB database.
Old Jun 8, 2007 | 11:52 PM
d*rock's Avatar
I had a rumble under my car that started after I put my JBA true dual exhaust system. At first, I thought it was the bumper, then I got a GT bumper. Noise was gone for a day. Then it came back. Anyone know where I can get dampers for a dual system like that?
Old Jun 9, 2007 | 09:16 PM
I have already had that TSB done for the exhaust vibration @ 850 rpm. Mine is while not moving and its not really a vibration you can feel but one you can hear (sounds like from the trans area).
Old Jun 19, 2007 | 10:10 AM
tucsondivots's Avatar
The dealership replaced my muffler at about 32K miles. Heard the vibration at idle or revving, especially at startup.
Old Jun 20, 2007 | 09:50 AM
I hear that 2, but where did your vibration sound like it was comming from ?
Old Jun 21, 2007 | 08:06 PM
Underneath, back right. I could go outside the car and hear it. Often it quit when it warmed up (this was when it was still cold in the morning).
Old Jul 11, 2007 | 08:29 PM
tungsten07conv's Avatar
I have the same thing I think and it is tranny related in my case. It goes away when the clutch is depressed. One day I will bring the car into the dealer, but it is 6 1/2 weeks old so I will wait a bit.
Old Jul 17, 2007 | 01:43 PM
07V6STANG's Avatar
See this scares me. My car is in the shop now having dual exhaust being installed. I believe they had to remove the dampener in order to make the GT Takeoff mufflers fit. I will say, many V6ers with duals I have talked to say they have not had an issue with vibration......only time will tell.
Old Jul 22, 2007 | 02:33 PM
Cam07's Avatar
I've got duel exhaust and I have a bad vibration when the car is stopped in drive, but when I shift it into neutral it goes away. I had the TSB done, but it didn't do anything.
Old Jul 22, 2007 | 03:46 PM
97svtgoin05gt's Avatar
Something is resonating. It should be easy to identify but you'd need it to be on the lift in drive and parking brake on.
Old Jul 22, 2007 | 06:52 PM
Ricklmesa@cox.net's Avatar
Get a new muffler & aluminum driveshaft and it should take care of it. lol
Ecostang
Nov 3, 2022 08:50 PM
RRRoamer
Jan 19, 2017 05:27 PM
jc46002003
Apr 15, 2016 03:00 PM
Wild5.0
'10-14 Exterior Modifications
15
Aug 4, 2015 11:22 PM
f1-cobra
Aug 1, 2015 08:02 PM
