V 6 Rear Sway Bar
Old Mar 8, 2005 | 02:21 PM
austexstang's Avatar
Has anyone put a rear sway bar, either OE or aftermarket, on their V6?
Old Mar 8, 2005 | 02:42 PM
kevinv-6's Avatar
no, hopefully later down the road I will.
Old Mar 8, 2005 | 03:20 PM
mm49's Avatar
Yes, Steeda Bar works very well and with the Eibach springs it handles like its on Rails !
Old Mar 8, 2005 | 04:29 PM
cosmo's Avatar
I put the one from Steeda for the gt It made a big differance I was happy with it . 349.00 sway bar and links
Old Mar 8, 2005 | 06:17 PM
Falchion's Avatar
That sounds like a cool mod! Maybe I'll get it.......
Old Mar 9, 2005 | 09:18 AM
Thanks MM49 & Cosmo.. That's what I needed to know. Glad you're happy with the Steeda bar.
Old Mar 9, 2005 | 11:18 AM
bison's Avatar
If you're going to add a rear bar, you should upgrade the front bar too, unless the rear bar is pretty soft. Adding a stiff rear bar and keeping the soft stock front bar will probably make the car oversteer, especially off throttle in decreasing-radius turns.
Someone will probably make a matched set for the V6, if they don't already.
Old Mar 9, 2005 | 03:09 PM
Drivetime's Avatar
MM49 - John - how do those Eibach springs feel and look compared to stock? Is the car lower now? What effect did they have on the ride?
Old Mar 9, 2005 | 03:20 PM
Eibach has a kit w/front & rear... I'll check that out also
robjh22
Dec 14, 2015 08:41 AM
Sep 16, 2015 06:44 PM
robjh22
Sep 8, 2015 12:31 PM
earl610
Sep 6, 2015 05:48 PM
