Throttle body
Old Nov 14, 2004 | 06:03 PM
mark221's Avatar
I don`t know if I`m reading something wrong but it looks like the 4.0 V-6 is 65mm where as the 4.6 V-8 is 55mm. What gives?
Old Nov 14, 2004 | 06:06 PM
Berol's Avatar
V8 might be dual 55's?
Old Nov 14, 2004 | 06:08 PM
mark221's Avatar
I thougt about that but isn`t 110 mm a bit big? What were the 04`s?
Old Nov 14, 2004 | 06:09 PM
hiznherponies's Avatar
It is!! Twin 55's, that is!!
Old Nov 14, 2004 | 06:17 PM
mark221's Avatar
Thanks for the info.55mm seemed small, but 110 seemed big, but I guess not.
Old Nov 14, 2004 | 06:39 PM
V10's Avatar
V10
Originally posted by mark221+November 14, 2004, 7:20 PM--></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (mark221 @ November 14, 2004, 7:20 PM)</td></tr><tr><td id='QUOTE'> <!--QuoteBegin-2MustangJohn@November 14, 2004, 7:12 PM
Thanks for the info.55mm seemed small, but 110 seemed big, but I guess not. [/b][/quote]
2 x 55mm is NOT the same as a single 110 mm.
Area of a circle = pi x R ^ 2
2 x 55 mm dia. = 4752 sq mm.
1 x 110 mm dia. = 9503 sq mm
Old Nov 14, 2004 | 07:49 PM
kevinb120's Avatar
Originally posted by V10+November 14, 2004, 8:42 PM--></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (V10 @ November 14, 2004, 8:42 PM)</td></tr><tr><td id='QUOTE'>
1 x 110 mm dia. = 9503 sq mm [/b][/quote]
Old Nov 14, 2004 | 07:52 PM
97svtgoin05gt's Avatar
Originally posted by V10+November 14, 2004, 7:42 PM--></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (V10 @ November 14, 2004, 7:42 PM)</td></tr><tr><td id='QUOTE'>
Whoa...math lesson......KEWL
Old Nov 15, 2004 | 03:32 AM
dke's Avatar
dke
Remember, we should be comparing 65mm to 2 x 55mm....or 4225 sq-mm to 4752 sq-mm-- the latter being larger.
Old Nov 15, 2004 | 05:23 AM
The Boss Hog's Avatar
Actually, when you consider the displacement of the V8 vs. the V6, they are almost the same but the V6 throttle body is slightly larger.
V6: 4225 mm^2 / 4.0 liters = 1056 mm^2 per liter of displacement
V8: 4752 mm^2 / 4.6 liters = 1033 mm^2 per liter of displacement
The Boss Hog
(Not sure what that proves . . . . . )
Old Nov 15, 2004 | 06:07 AM
dke's Avatar
dke
Excellent point.
Of course, doesn't the more valves per cylinder help. (Better breathing with 2 intake vavles can make up for slightly reduced manifold breathing?). I understand it is just about airflow -- but I also wonder about other things... are there less turns in the intake, what's the polish/turbulence, length, dia of the master, and so on.
I'm pretty sure that Ford knows a lot more than I do about their engines, and balanced things pretty well ;-)
kponypower
Jun 17, 2020 07:17 AM
GLOCKer
Sep 28, 2015 05:20 PM
Stephen Laslo
V6
Sep 18, 2015 07:57 PM
