these LCA's proper?..
http://powerhouse411.com/catalog/index.php...6&products_id=1
I just wanted to know if these were a good brand to go with, I know a couple of people have them. How are they on the noise factor? Im not planning on getting them installed right away unless its cheap. How much would the labor be about? Would that be all I needed to buy? They say they don't need grease, there is no other parts that would be needed for my shop to installed them?
Thanks for your time
i love mine, but im a track junkie.
i know shops charge between 50 and 150 to install them, id be that 50 end at my shop.
yes its going to make things noiser, at least theoretically should, especially over bumps
mine were noisy for like the first hour is all i would say it was kinda weird....but after that I'm really happy with mine. like Fazm said they're friggin sweet at the track, unless you're into the hoppin kinda thing [img]style_emoticons/<#EMO_DIR#>/tongue.gif[/img]
i have bmr with grease fittings no noise no wheel hop had them 2 mths 119.00 at stang susp
installed mine in one hour if you known how to use wrenchs no problem?
the noises are just from havin a stiffer rear, so bumps cause more rattles. Especially if you have an aftermarket exhaust.
http://www.bmrfabrication.com/2005Mustang.htm
i got...
http://powerhouse411.com/catalog/index.php...dex&cPath=1_3_6
i got...
Antigini-GT/CS
10/5/15 09:43 AM
9/23/15 03:21 PM
9/1/15 01:19 PM
