Street Scene V6 to GT Conversion Grille Shell
Old Nov 19, 2005 | 12:59 PM
Gearhead's Avatar
I just installed the Street Scene V6 to GT Conversion grille, which holds the stock GT Fog lights in the standard outboard position. Installation was quick and easy, and the look is good. I did find that the Grille Pony does not bend, even with the application of heat from a hair dryer. I just mounted the Pony with the existing Ford backer-washer things and secured under the center two washers with a loop of two small black zip-ties. You are still mounting a flat Pony on a curved surface, but it actually looks fine.
For wiring, please see my previous instructions (also with input from Flight96):
http://forums.bradbarnett.net/index.php?showtopic=37282
The color on this grille is Black Powdercoat, which is the stock look for the Mustang. The Muscle Car Direct part number for this grille is SSE-74591, and the Street Scene part number is the similar 950-74591.
I would also add that the stock low beams on the Mustang really aren’t adequate for nighttime rain driving. The addition of the Fog lights is a very worthy safety upgrade, as the ability to see is much improved.
Old Nov 19, 2005 | 07:39 PM
afixer's Avatar
looks great i use a heat gun and mine bent just fine
gear i also painted the grill area satin black so all you see is the grill. i love this way much better than the others.
Mar 30, 2021 09:29 AM
Cobiecane
Oct 23, 2015 08:44 AM
mlcinema
Oct 7, 2015 10:05 AM
