Nitrous on V6
Old Aug 17, 2005 | 09:32 PM
Fazm's Avatar
In case none of you are members on stangnets forum as well, you really should check this out.
http://forums.stangnet.com/showthread.php?t=569430
i have the full specs on the car, and to get those hp #s (302rwhp, 439rwtq) is less then $3500
Old Aug 17, 2005 | 09:56 PM
TURBO 05's Avatar
those are some awsome numbers
Old Aug 17, 2005 | 09:57 PM
kevinv-6's Avatar
i need two more jobs at least...
Old Aug 17, 2005 | 10:25 PM
ManEHawke's Avatar
Wow, that increase is very good.
So how many hard launches before our tranny blows lol. Man launching with over 400ft/lbs!! amazing
Is there any research on what it takes to get the GT's whole drivetrain minus the engine? If aftermarket solved this it'd be hitting a goldmine.
Can't wait to see your results
Old Aug 17, 2005 | 10:39 PM
TURBO 05's Avatar
You can get a tremec tranny for about $1200, a better clutch for about $300, a driveshaft for about $300, an 8.8" rear end assembaly with axles and brakes for ummm i dunno about a grand i guess. So you could do it for about $2800 which is still cheeper then the GT even with the NOS
Old Aug 17, 2005 | 11:01 PM
Fazm's Avatar
Then just slap some gt badges on it and go! haha (im jokin by the way)
Old Aug 17, 2005 | 11:08 PM
ManEHawke's Avatar
lol, any idea on how compatible new tranny and 4.0 would be. If it's more trouble than worth then I probably wouldn't consider it.
I still can't believe all that torque though.
Old Aug 18, 2005 | 02:48 AM
1trickpony's Avatar
That torque is totally f***ing sick. This would crush an average GT. Why did he stop the dyno pull at 5500 rpm? Still HP was 300 all over the place. I'm sorry if I missed it, but all of that power came from just a NEX system? I think a 4.0L engine can take 300 HP+. The tranny and rearend will blow with drag radials and gears. 400 pounds of torque and a T-5 with a 3.75 first gear is a ticking time bomb. Still this is awesome potential. Just thank what ported heads and a cam with this could do.
Old Aug 18, 2005 | 03:50 AM
scrming's Avatar
Well, that's one nice thing about getting a V6 WITH the automatic... it's the same one that's in the GT! So I know it will take some serious abuse... LOL!
Old Aug 18, 2005 | 05:45 AM
1trickpony's Avatar
Good point, the auto should be stronger than the T-5. I'd say the auto can take 400 hp, the T-5 maybe 300. I'm basing this on long-term reliability.
Old Aug 18, 2005 | 09:59 AM
xxkazp3rxx's Avatar
Just remember all the V6's have the 7.5 rear end... the real question is can the rear end take it?
Old Aug 18, 2005 | 02:54 PM
1trickpony's Avatar
I think it is Dan Haga, V6racing.net has a heavily modded 3.8L. Nitrous, head work, everything. I think he blow the rearend with 350 HP or so. The car also had drag tires and gears. I guessing its how you have your car set up. Normally the rearend is the first thing to go, but the really short gears in the 05 T-5 has me concerned. A 7.5 is reported to be 35% weaker than a 8.8.
Old Aug 18, 2005 | 10:17 PM
TURBO 05's Avatar
i know people running 8.8" up to 800 hp i dont know about the 7.5 but my buddy who took a fox 4 cyl and converted the engine and tranny to 5.0 with 320hp w 4.10's, killed his right away
Old Aug 19, 2005 | 05:50 AM
scrming's Avatar
Ok... Took my car back to the shop that did my 4.10/Track-Lock to have the oil changed (700 mile for break-in). I was talking the the guy who put it all together. Talked to him for quite a while and this guy knows his stuff! I asked about the durabitly of my 7.5. His bottom line was that the 7.5 should be good enough for me... He said what usually gets guys in trouble is when they swap out the v-6 for a big v8, have a manual tranny and then put on slicks. He said that's when you will see your spider gears "explode". He said I don't need to worry about that now since I went to the Track-Lock. So for the time being I'm thinking the 7.5 is going to hold up....
Omegaprime92
1994-2004 V-8
Sep 8, 2015 08:53 AM
JonathonK
Which is Better
Aug 30, 2015 06:14 AM
Vegasjay
51
Dec 9, 2005 12:11 PM
speedslave
36
Sep 29, 2005 12:35 PM
