My next mod: LCA's (what to get?!?!?)
Old Feb 11, 2006 | 10:24 AM
rygenstormlocke's Avatar
Well, I'm researching for my next mod, and wanted to get some opinions before I pull the trigger. Also wanted to get some opinions on UCA's as well, and if they are really needed.
So far, I like what I hear on the BMR's, here is what I'm looking to get:
http://www.bmrfabrication.com/2005Mustang.htm
TCA019 Tubular Lower Control Arms w/poly bushings $119.95 pr.
Heres a pic of them:
I have never had LCA's put on my car, so I welcome everyone's input on them. Thanks everyone!
Old Feb 11, 2006 | 10:48 AM
Thomas S's Avatar
I've been thinking of getting the Powerhouse LCAs.
Powerhouse LCAs
Old Feb 11, 2006 | 10:51 AM
<div class='quotetop'>QUOTE(BlackLX4.0 @ February 11, 2006, 12:51 PM) Quoted post</div><div class='quotemain'>
Powerhouse LCAs
[/b][/quote]
Good find, I can definitely trust Mike when it comes to stuff like this. No doubt these are on his V6 project car.
Old Feb 11, 2006 | 10:55 AM
Thomas S's Avatar
<div class='quotetop'>QUOTE(rygenstormlocke @ February 11, 2006, 1:54 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
I like that you don't need to grease them and the built-in parking brake cable retainer.
Old Feb 11, 2006 | 10:56 AM
<div class='quotetop'>QUOTE(BlackLX4.0 @ February 11, 2006, 12:58 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
Yes, the built in parking brake retainer caught my eye too. Do other's not support that?
Old Feb 11, 2006 | 11:00 AM
Thomas S's Avatar
<div class='quotetop'>QUOTE(rygenstormlocke @ February 11, 2006, 1:59 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
None of the one's that I've seen. I've been itching to order those, just waiting until I pay off my CC. Maybe I won't wait, heh. [img]style_emoticons/<#EMO_DIR#>/04.gif[/img]
Old Feb 11, 2006 | 11:20 AM
TJ06's Avatar
<div class='quotetop'>QUOTE(rygenstormlocke @ February 11, 2006, 11:27 AM) Quoted post</div><div class='quotemain'>
[/b][/quote]
Rygn see if there is anything here you like [img]style_emoticons/<#EMO_DIR#>/smile.gif[/img]
http://exoticperformanceplus.com/performan...ml?category=183
I would definitely pick up the drive shaft loop!!
I would also put a call in to Mike and PHP.
Old Feb 11, 2006 | 11:56 AM
<div class='quotetop'>QUOTE(TJ06 @ February 11, 2006, 1:23 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
Thanks! So the drive shaft loop reinforces my drive shaft? What exactly does it do?
Old Feb 11, 2006 | 12:13 PM
TJ06's Avatar
<div class='quotetop'>QUOTE(rygenstormlocke @ February 11, 2006, 12:59 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
Rygn it's a safety issue with the amount of TQ you will be pulling if (and they could) U joints break the drive shaft will pop off your rear end spinning out of control at a high RPM and could strike you gas tank and that could be dangerous. I would research more because that one said front drive shaft loop which will help but also research it there is a rear loop I thought I read there was a rear awhile ago.
Old Feb 11, 2006 | 12:15 PM
Scrib's Avatar
You only need a driveshaft loop if you are going to run slicks - it's a safety item required by most tracks (keeps the car from flipping if the front u-joint breaks). But, it's only required for cars running slicks.
Old Feb 11, 2006 | 12:18 PM
Hmmm, won't be running slicks this season, but will research it none the less. Thanks everyone.
Old Feb 11, 2006 | 12:44 PM
TJ06's Avatar
<div class='quotetop'>QUOTE(Scrib @ February 11, 2006, 1:18 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
Rygn & Scrib in the quote below the guy is not running slicks but street tires, its you're call but Rygn I would install one it's a low cost item. You will be pulling a high amount of TQ that Ford did not test with on the rear end U joints or drive shaft.
<div class='quotetop'>QUOTE</div><div class='quotemain'>"You can look at the pic and see the car has tires that hook up pretty good. I've changed the axles and drive shaft. Also added a safety loop since Ford ran the gas tank right next to the drive shaft. Really good thinking! I don't mind the spinning I'm guessing in the long run if it hooks up I'm going to break something. On another sh-ty note no parts. Looks like another 7-10 days at the least. This really Sucks!!!" [/b][/quote]
Old Feb 11, 2006 | 02:24 PM
<div class='quotetop'>QUOTE(TJ06 @ February 11, 2006, 2:47 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
Well for 100 bucks if it is more safe than I'll do it, just want to do more research on it. But I appreciate you digging this up man. A small price to pay to take extra precautions.
[img]style_emoticons/<#EMO_DIR#>/thumb.gif[/img]
Old Feb 11, 2006 | 02:32 PM
Puerto Rico 4.6's Avatar
If u are running an x pipe set up if the driveshaft goes it will rest on top of the x pipe,Wouln't it?
Old Feb 11, 2006 | 05:06 PM
Scrib's Avatar
Uh...no. You'll lose those pipes, the floorboard tunnel, and lots of other stuff. It's pretty violent, even with a driveshaft loop.
Old Feb 11, 2006 | 10:33 PM
If it doesnt hit the ground how can it come up and cause all that havoc u are describing...
SpectreH
Feb 22, 2015 02:04 AM
barebone- 5.0
Jul 10, 2014 06:35 AM
SteelTownStang
May 3, 2013 04:38 PM
Dayve
2012-2013 BOSS 302
Feb 9, 2013 07:53 AM
Double-EDad
Off-Topic Chatter
31
Oct 15, 2011 10:10 PM
