idling question
if anyone can tell me its normal il feel fine
car is completely stock for now
whenever i idle for extended periods of time in this lovely long island traffic like 10min + and while driving no more than 3 mph between lights the engine RPM drops a teeny bit every 10 seconds or so ..enough so i notice it by the sound
normal??
this due to the fan having to spin constantly?
normal??
My manual transmission doesn't do this. If this isn't common to the autoboxes, then it could be caused by a marginal throttle position sensor or a coated oxygen sensor. Does anyone else with an autobox experience this? If not, off to the dealership with you.
On my manual I noticed for a long time that the car when idling would rev itself a little bit then drop back down every 10 seconds of so, but the RPMs were actually picking up. I cant remember experiencing this since the car was tuned so I would point towards something to do with a throttle position sensor as well.
yea it drops down a tiny bit .. just enough to make the car shudder for a second then goes up again...only after idling for entended periods
talking maybe from 600rpm to 500 for 1 sec every 10 seconds
<div class='quotetop'>QUOTE(jcopin @ February 28, 2006, 9:58 AM) Quoted post</div><div class='quotemain'>
definately not AC about 35 outside last time it did it =p
[/b][/quote]
Yes, as stated it doesn't have to be A/C selected, any defrost settings will cycle the a/c compressor.....sorry about that 35 degrees.......although it has been cool down here in Bama also.
[/b][/quote]
