idling question
Old Feb 25, 2006 | 09:02 AM
jcopin's Avatar
if anyone can tell me its normal il feel fine
car is completely stock for now
whenever i idle for extended periods of time in this lovely long island traffic like 10min + and while driving no more than 3 mph between lights the engine RPM drops a teeny bit every 10 seconds or so ..enough so i notice it by the sound
normal??
this due to the fan having to spin constantly?
Old Feb 26, 2006 | 12:19 PM
Gearhead's Avatar
My manual transmission doesn't do this. If this isn't common to the autoboxes, then it could be caused by a marginal throttle position sensor or a coated oxygen sensor. Does anyone else with an autobox experience this? If not, off to the dealership with you.
Old Feb 26, 2006 | 02:42 PM
Zodiac's Avatar
On my manual I noticed for a long time that the car when idling would rev itself a little bit then drop back down every 10 seconds of so, but the RPMs were actually picking up. I cant remember experiencing this since the car was tuned so I would point towards something to do with a throttle position sensor as well.
Old Feb 27, 2006 | 10:15 AM
jcopin's Avatar
yea it drops down a tiny bit .. just enough to make the car shudder for a second then goes up again...only after idling for entended periods
talking maybe from 600rpm to 500 for 1 sec every 10 seconds
Old Feb 27, 2006 | 03:48 PM
05V6's Avatar
This may be your A/C clutch cycling. If you are running defrost settings or A/C settings your compressor will cycle.
Old Feb 28, 2006 | 08:55 AM
jcopin's Avatar
definately not AC about 35 outside last time it did it =p
Old Feb 28, 2006 | 04:04 PM
GMC Woo's Avatar
The AC doesn't have to be selected. If you have the blower running, the AC compressor cycles. It's almost as if the system thinks it's got low pressure. Don't know why, it just does.
Asa
Old Feb 28, 2006 | 08:02 PM
05V6's Avatar
<div class='quotetop'>QUOTE(jcopin @ February 28, 2006, 9:58 AM) Quoted post</div><div class='quotemain'>
[/b][/quote]
Yes, as stated it doesn't have to be A/C selected, any defrost settings will cycle the a/c compressor.....sorry about that 35 degrees.......although it has been cool down here in Bama also.
CNFLCTD
GT350
Aug 4, 2017 07:08 AM
MustangConvert11
Sep 30, 2015 08:01 PM
