idles bad
Old Mar 28, 2015 | 07:32 AM
silverstang417's Avatar
idles bad
after I cleaned my throttle out now the car decides to idle rough like 1 to 1 1/2 then it bounces back and fourth anyone no wat the matter could be
Old Mar 28, 2015 | 09:47 AM
Did you disconnect the battery when you cleaned the TB? Did you remove the TB when you cleaned it? Try disconnecting the battery for 5 to 10 minutes or so and see if that helps
Old Mar 28, 2015 | 01:33 PM
Yes I took the tb off to clean it
Old Mar 29, 2015 | 09:30 PM
jim010's Avatar
I have a similar issue. What is TB?
Old Mar 29, 2015 | 09:34 PM
LivinTheStangLife's Avatar
throttle body
Old Mar 29, 2015 | 09:49 PM
jim010's Avatar
Ok. With my 12, sometimes on start up I also have rough idle and it seems to 'clunk' and then it idles normal. Is this what the OP is experiencing? Cause I'd love to know what the issue is too.
Old Mar 30, 2015 | 10:02 AM
FordServiceCA's Avatar
CURRENTLY NOT ACTIVE ON THIS SITE DO NOT USE PM FEATURE!
Hey there, jim010.
What's the dealer diagnosis? Send that over, along with the current odometer reading and dealer name; I'll look into this.
Nikki
Ford Service CA
Old Mar 30, 2015 | 10:10 AM
jim010's Avatar
Hi Nikki,
The car is off waranty, so if this is a fix I can do myself then I will go that route.
Cheers
Old Mar 30, 2015 | 03:51 PM
My dealer mechanic stated that it could me many things wrong like 02 sensor out or new fuel filter or pump
Old Mar 30, 2015 | 05:29 PM
did you disconnect the battery?????????
Old Mar 30, 2015 | 09:05 PM
No I didn't they said that wouldn't matter if I did or not
Old Mar 31, 2015 | 05:46 AM
SpectreH's Avatar
It might not matter, but it doesn't cost anything to try and if it works, saves you time and money.
Old Mar 31, 2015 | 06:07 AM
it resets the computer.
Old Mar 31, 2015 | 09:05 AM
They r saying it has nothing to do with resetting the computer
Old Mar 31, 2015 | 10:21 AM
SpectreH's Avatar
All Glenn and I are saying is it does not hurt to try the reset. What do you have to lose other than a few minutes of your time?
Old Mar 31, 2015 | 10:42 AM
Buy a new TB??
Old Mar 31, 2015 | 11:54 AM
Ok I just reset my computer and it didn't work
Old Mar 31, 2015 | 11:58 AM
jim010's Avatar
It didn't work for me either when I did it.
Old Mar 31, 2015 | 12:18 PM
Idk wat else it could be
Old Mar 31, 2015 | 01:37 PM
vacuum leak??
