idles bad
after I cleaned my throttle out now the car decides to idle rough like 1 to 1 1/2 then it bounces back and fourth anyone no wat the matter could be
Did you disconnect the battery when you cleaned the TB? Did you remove the TB when you cleaned it? Try disconnecting the battery for 5 to 10 minutes or so and see if that helps
Yes I took the tb off to clean it
I have a similar issue. What is TB?
Originally Posted by jim010
(Post 6913265)
Ok. With my 12, sometimes on start up I also have rough idle and it seems to 'clunk' and then it idles normal. Is this what the OP is experiencing? Cause I'd love to know what the issue is too.
(Post 6913268)
What's the dealer diagnosis? Send that over, along with the current odometer reading and dealer name; I'll look into this. Nikki Ford Service CA |
Hi Nikki,
The car is off waranty, so if this is a fix I can do myself then I will go that route. Cheers |
My dealer mechanic stated that it could me many things wrong like 02 sensor out or new fuel filter or pump
did you disconnect the battery?????????
No I didn't they said that wouldn't matter if I did or not
Originally Posted by silverstang417
(Post 6913663)
It might not matter, but it doesn't cost anything to try and if it works, saves you time and money. |
it resets the computer.
They r saying it has nothing to do with resetting the computer
All Glenn and I are saying is it does not hurt to try the reset. What do you have to lose other than a few minutes of your time?
Buy a new TB??
Ok I just reset my computer and it didn't work
It didn't work for me either when I did it.
Idk wat else it could be
vacuum leak??
