GT dual exhaust how-to
Old Jun 4, 2005 | 07:40 PM
Tres Wright's Avatar
For those interested, I just posted a how-to thread on installing GT muffler duals with pictures and part numbers here:
http://www.mustangforums.com/m_555524/mpag..._/tm.htm#555536
[attachmentid=23268]
Old Jun 4, 2005 | 08:32 PM
ManEHawke's Avatar
Do the two pipes ever meet? Did Midas weld in an H or cross them for an X?
Sounds like a good deal, I'd love to do duals later down the road. Have you noticed any loss or gains in power, and did you get a tune?
Old Jun 4, 2005 | 09:11 PM
The new left pipe ties into the existing left side head pipe just past the cat. So the existing tie-in from the left pipe to right is still there, it acts as kind of a y-shaped crossover. I can't say I'm too happy with that, it's likely not the most efficient setup.
I can't tell a difference in performance. After I added the right side GT muffler and the K&N filter it did feel like it had more pep, but the dual GTs don't seem to have added (or lost) anything over the single GT. I mainly did it for the looks though, I never did like the single exhaust sticking out the back!
I have not gotten a tune. I probably will some day after they get the tunes dialed in better for the V6.
Old Jun 4, 2005 | 11:03 PM
ManEHawke's Avatar
ok heres what I got in mind from what your description. You can either confirim or fix what I have concluded using my mad paint skills
stock way
[attachmentid=23303]
how you have it
[attachmentid=23304]
If that's the case, it's actually not that bad of a setup.
Old Jun 5, 2005 | 08:50 AM
Hey, that's not a bad sketch! Quite right, that's exactly what I was trying to describe
Old Jun 5, 2005 | 11:32 AM
flight96's Avatar
You mention that there are holes in the frame rail for the brackets. Did I read right that they are not threaded?
Old Jun 6, 2005 | 01:03 PM
shave35's Avatar
Yes that is right, they are not threaded. But having said that once you screw in a bolt they become threaded. Just make sure you are aimed straight in and you we not have a problem.
Old Jun 6, 2005 | 02:54 PM
What Shave said If you buy the extra hardware at Home Depot, use one of the factory bolts to chase the threads first. It's easier to get them lined up because the first 1/4" or so of the factory bolt is an unthreaded lug.
Old Jun 7, 2005 | 10:20 AM
flight96's Avatar
Thanks, I have access to many taps/dies so threading will not be a problem, I just wanted to make sure I read it right....Thanks again, great info !!!
CiniZter
25
Apr 28, 2016 05:41 PM
Sep 24, 2015 08:15 PM
mustangsally_
Sep 18, 2015 05:35 AM
