Glenn Thats it. As I said earlier CAI with out the reducer spells codes unless you have a tune.
Originally Posted by silverstang417
(Post 6897748)
I was just told that the 87 octane tune I put on my car plus my true duel exhaust may have caused my 02 sensor to go out
(Post 6897750)
Plus I just had another code go off it was a p0300 which said random misfire
(Post 6897793)
All I've done I put a cold air intake on it
Maybe the MAF sensor went back in the wrong direction, if all you did was CAI doesn't make sense
Originally Posted by cdynaco
(Post 6897821)
:doh:
Silver Are you reading any of our responses...:poke: |
Yes me and my mechanic r both reading it
My wife got the cai for me for christmas
(Post 6897855)
Running lean on these modern engines = piston failure :explode: |
I have a tuner and I have a tune put in my car which tune should I need
where is your tune from? Was it one that was installed in your tuner when you bought it?
If so I would call Steeda or one of the other tuners out there and get a tune that matches your intake. Don't drive your car to much while its throwing that code. Put your stock intake back on and reinstall your stock tune |
Originally Posted by Jazzman442
(Post 6897816)
Yes ... if you are running the Steeda CAI ... you will definitely need a tune or a revision.
If you didn't purchase from us ... we can write you a tune for $99.00 or enroll you in our tunes for life for $150.00. Let me know ... you can send me an email to tim@steeda.com & we can get you squared away with a tune! Best Regards, TJ |
I run an SCT tuner from bama with bama tunes
I guess I would call them and have them go over the tune file with you. They may have clicked on something they shouldn't have. I had one of their tunes throwing a to rich code recently and they wanted me to data log. I didn't think I should have to do that. So I called them and insisted we go over the file. They found a problem with the tune and sent me a revised tune which seems to be alright now. They even said but sir that is the same tune we send out to many customers. Sad part is I went and had a diagnostic test done for 90 bucks thinking there was something wrong with my car. 90 bucks is a nice chunk of beer money.
My maxhanic never charges me to do a diagnostic test on my car but I've had this tune in for almost 7 months noe
I order all my tunes from american muscle
swap o2 sensors to the opp side and see if the code returns as mentioned already I think. If it does then you know its most likely the sensor. If you get the same code that is.
Funny story my wife was driving it to the for dealership and the check engine light went off when she hit a bump
well don't hit any more bumps
Originally Posted by Glenn
(Post 6898256)
wooooohooooooooo
The suggestion to go back to stock was to see if the code went away. But hells yea no more bumps is where its at |
