A couple of Zex questions
Old Feb 17, 2006 | 12:46 PM
Thomas S's Avatar
1) Jets. I'm looking at the Zex website at the jet chart:
http://www.zex.com/Products/JetCharts.asp
And it's showing different jets for the V6 and the V8. Now all of us that have Zex are probably going by the instructions that came with our kit, which is for the GT. Should we be using the smaller jets?
2) Spark plugs. I see that Rygen is using NGK Iridiums. Is that a colder plug than stock? Is that the best plug for us? I've seen plenty of people saying good things about that plug.
TIA for any info. I know I could just call Zex but I thought I'd open it up for discussion. Maybe others could benefit.
Old Feb 17, 2006 | 01:27 PM
scrming's Avatar
<div class='quotetop'>QUOTE(BlackLX4.0 @ February 17, 2006, 2:49 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
1) I'm acutually using the 100HP Nitrous jet and the 75HP Fuel jet. We found that combination gave us the most consistent A/F with and with out spraying... that way if I leave my Nitrous tune in the car it will still have a good A/F even if the Zex is off... We did this when I switch to the C&L... I'm going to have at least 1 more solid dyno session before the track opens... just to verify the A/F again...
2) Our spark plugs are already a cooler plug... We pulled a couple of plugs to check them... Lidio noticed it was a colder range and commented that it meant no need to change the plugs... the plugs look absolutely fine... he did say we should probably re-gap them when we get a chance... close them down a bit...
samjluck
Sep 17, 2015 10:24 PM
50Cal
Sep 17, 2015 06:43 PM
TripleBlack14
Off-Topic Chatter
Sep 12, 2015 01:03 PM
