Check Engine Light On
My car just turned 3,000km and the "check engine" light came on. The car seems to run fine, no different. I checked oil/antifreeze and all is good. Is it set to go on at 3,000km . Has anyone else had this problem with their V6? I seen in the GT forums a few issues but I couldn't find this in the V6 area.... :scratch:
The check engine or service engine soon lamp indicates a fault in the engine control system. If your car is running good it is not a critical concern, but get it in to your dealer at your earliest convenience for diagnostic and repair.
OK, so here's what they found. NOTHING :scratch: The error code that came up was EVAP. Which, they explained, was for a vacuum leak somewhere in the fuel system. However he also said that it may have been caused by not having the gas cap tightend. I know that sounds weird but I have heard of this before. They checked all the seals and they were all fine. So there ya go. Hopefully their right!!!
Originally posted by Zodiac+March 19, 2005, 10:46 AM--><div class='quotetop'>QUOTE(Zodiac @ March 19, 2005, 10:46 AM)</div><div class='quotemain'><!--QuoteBegin-flight96@March 19, 2005, 11:25 AM
[/b][/quote]
No it didn't go off on its own, they had to reset it. I got them to do the first servicing while it was there as well.
ClayP
8/11/15 06:23 AM
