Any 5-speed MANUAL V6's yet?
Old Jan 6, 2005 | 09:46 PM
Doug@C&L's Avatar
Hey guys,
I've been looking all over for a manual mustang because I need the VIN number to order the bellhousing for my 4.0 SOHC. I've tried Ford parts with absolutly no help and they said if I can give them a VIN number then they can get a entire parts sheet for a car and get it then but without one I'm lost. I've reviewed every dealer in town's inventory online and even tried building on off the Ford site and still can't get a V6 with a manual.
Does anyone have one? If so would you please send me your VIN number so I can get a bellhousing.
Thanks, Doug.
Old Jan 6, 2005 | 09:56 PM
jsheehan's Avatar
1ZVFT80N055136079
Found that on fordvehicles.com
There is a dealership near me that has a few. Got The VIN off the site.
Old Jan 7, 2005 | 05:59 AM
Tiberius1701's Avatar
Went on to Ford's Vehicle Bill of Materials website, no bellhousing exists. I am quite sure that the trans and bell housing are one unit.
Old Jan 7, 2005 | 07:34 AM
orange3.9stang's Avatar
Ford is still using the T-5 Manual Transmission on V6 Mustangs. As far as I know, this Trans has always had a separate bellhousing. However there are changes Ford has made to the 2005 transmission (shifter location for one), so it is quite possibe that they integrated the bellhousing like on the Tremec 3650 used in the 4.6L GT from '96-current.
Old Jan 8, 2005 | 11:01 AM
Wintrmte's Avatar
Yep, I picked mine up yesterday. V6 Mineral Grey with 5 speed standard.
The shifting is very very smooth, except for going into 5th gear.. It's a bit of a reach to get there, I've found.
Clutch is very nice, although I can feel somewhat of a vibration in the pedal.. I'm not sure if that's just because the car is new, or??
Anyhow, I'm in love with it.
I'll run out to the garage and get the VIN and PM ya.
Old Jan 8, 2005 | 01:02 PM
Falchion's Avatar
Yeah, I test drove the V6 manual a couple of weeks ago and I really liked it!
It was a lot of fun, the car is really a lot of value for the money.
Just don't go for a V6 Auto, it wasn't as much fun..... :nono:
Old Jan 8, 2005 | 02:42 PM
Zodiac's Avatar
The reach into 5th is huge, but Ive only gotten the chance go actually go into 5th maybe 5 or 6 times in the couple of weeks Ive had the car. The darn thing just doesnt want to change out into 5th until like 70 and I just dont get the chance to cruise up there that much haha. As for the clutch, its just pedal feedback. Its a good thing, I promise
Old Jan 8, 2005 | 03:47 PM
James4litre's Avatar
I found reverse hard to engage on any type of a hill. This has gooten less and less noticeable the more miles i get on it. Anyone else noticed this?
Old Jan 8, 2005 | 04:29 PM
Zodiac's Avatar
I still have a hard time getting it to go into reverse at all sometimes... even on flat ground. Usually if I shift up into first then back out and go down to reverse itll go in. The shifter still feels really stiff going into gears, like it locks out or something, especially at higher RMS and when Im trying to shift fast. Double clutching doenst seem to help it any, either. Im just at the 1K mile marker.
Old Jan 9, 2005 | 12:04 PM
sundeep's Avatar
Same problem here too, I sometimes have to shift to second then straight to reverse to get it into gear...
Hopefully more miles will make this go away.
Old Jan 16, 2005 | 10:34 AM
Doug@C&L's Avatar
Thanks guys,
I've had them order another bellhousing with a different part number and they still got it wrong. The bad part is they got the correct front bearing retainer for the transmission.
On a side note I hate it when the parts guys try to make excuses for Ford, the guy I was using tried to tell me they were just using the same bellhousing for all the engines this year, ahahahahaa. What dumbazz, the starters on the 4.0's aren't even on the same side as the 4.6's. Gee's.
I've got a 4 liter Performance bellhousing that I guess I'll have to use for the T-5 I just wanted to go all Ford parts but until it's right I'll use what I got.
Thanks!! Doug.
Old Jan 16, 2005 | 04:59 PM
Rogue6's Avatar
If the V6 manual is anything like last years, there was a trick that kept the driver from shifting quickly from 1st to reverse. With my '01 I had to put it in neutral, let off the clutch, re-engage the clutch and shift into reverse. It would usually go in with no muss and no fuss then.
Good luck...I order mine in April. It sounds like with all the delays on the IUP that I may end up with an '06 though.
Old Jan 16, 2005 | 07:38 PM
Fazm's Avatar
I noticed that reverse is somewhat hard to get into when in my driveway, i thought i had put it in, but when i let out on the clutch, it popped out of gear, then read this thread... so i know im not alone
Old Jan 18, 2005 | 06:23 AM
sviper's Avatar
Yeah runs great and reverse is something less than desired as far as ease to go in to when cold :bang: , noticed that after tranie warms up it is easier to get it in to reverse. Fifth is a long throw though compared to first through fourth.
blackhawkkid308
1994-2004 V-8
18
Dec 22, 2015 03:17 AM
mx5jhb
Sep 30, 2015 04:44 PM
Kalel08
Sep 29, 2015 03:06 PM
BigHoss
Sep 21, 2015 10:03 AM
jim010
Sep 14, 2015 10:15 PM
