05 4.0L dropped valve
Old Mar 23, 2015 | 04:06 PM
BillyDaKid's Avatar
Changed out the "Hurt" engine in the Screaming Yellow Stang this past weekend. With both motors on engine stands side by side to change over Alt. / AC/ PS Pump, took about 10 hrs. with power tools. It helped that the 42k Salvage yard motor had all brackets and wiring harness (parts) attached. Harness was cut but all plugs were still attached. Only glitch is bleeding stupid clutch slave cylinder. plastic line from master with plastic coupler between. Mr. Ford, what in the crap were you thinking? The next clutch change, I will buy a stainless brake line with the proper connections and go from master cylinder directly to the throw-out slave cylinder. I was going to keep the old motor for parts (only $100 core) until I pulled the pass. side valve/cam cover. The back cylinder had a broken spring a loose rocker and no valve. I was in the cylinder and the head was cracked all the way across from the piston achieving top dead center. New engine roars like a Lion (maybe Bobcat)
Old Mar 23, 2015 | 04:22 PM
great news glad it went well
Old Mar 23, 2015 | 04:34 PM
BillyDaKid's Avatar
Thanks, Sometimes dreading the job is worse than doing it. Power tools and a good friend makes the job easier.
Old Mar 24, 2015 | 09:06 AM
BillyDaKid's Avatar
Glenn, is the aluminum drive shaft a one piece unit or a two piece like OEM?
lsingggh310
Ecoboost
Feb 7, 2016 12:26 PM
Fords4Ever
Oct 30, 2015 09:07 PM
Airborne42
Sep 24, 2015 10:27 AM
bconboy
Sep 10, 2015 02:31 PM
BavarianStang
Sep 5, 2015 05:55 AM
