Zex Install
I like that bracket the controller is mounted to, you make that yourself? I haven't seen that before.
I like the switches too, but I think I would have put everything on the e-brake adjust panel thing, seen that done before.
<div class='quotetop'>QUOTE(dustindu4 @ February 5, 2006, 11:46 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
I made the panel.
[/b][/quote]
I made the panel.
Yeah, that looks like a little bit of an uncomfortable switch location. Won't be using it "on the fly" very much I guess.
<div class='quotetop'>QUOTE(Enfynet @ February 5, 2006, 11:06 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
you just need an arm and bottle warmer switch. the N2O engages on WOT
[/b][/quote]
*blank stare*
Coooool! [img]style_emoticons/<#EMO_DIR#>/thumb.gif[/img] [img]style_emoticons/<#EMO_DIR#>/thumb.gif[/img]
[img]style_emoticons/<#EMO_DIR#>/huh.gif[/img]
<div class='quotetop'>QUOTE(dlc @ February 6, 2006, 2:56 PM) Quoted post</div><div class='quotemain'>
Maybe. Just a 75 shot for now.
[/b][/quote]
yeah that's what they all say
If (or should I say when) I get a Zex I'm going to throw my 125 nozzle away
[/b][/quote]
you can with the 100 shot, maybe. I've seen a car run 11.53 on the 125 shot. Just make sure you get your car dyno tuned with the nitrous before you even try using it. Get custom tunes for 75, 100, 125 shots.
Your car will sputter at the end of the run with the 125s due to the slow fuel pump.
Is yours a manual?
Is yours a manual?
Is yours a manual?
Is yours a manual?
His sig says "tuned by Tim at Modular Powerhouse"
