X pipe
Old Sep 26, 2012 | 12:13 AM
mrnickelus's Avatar
X pipe
Does the x pipe replace the stock cat or is the xpipe instilled after the cat
Old Sep 26, 2012 | 05:32 AM
05YellowGT's Avatar
Just the H-pipe portion , the cats stay as they are ...
Old Sep 26, 2012 | 05:45 AM
orrrrrrrr you can order one without the cats
http://search.americanmuscle.com/sea...=mustangtuning
Old Sep 26, 2012 | 08:27 AM
Rickybender's Avatar
You can also order it with hi-flow cats for better performance gains and to keep the exhaust note down if you like it quite.
Old Sep 30, 2012 | 01:17 PM
mrnickelus's Avatar
No I want it loud. Put I don't have the money to tune it right now do I need to keep the cats. And if I delete the cat an a hand held tuner turn on the code that it will throw?
Old Sep 30, 2012 | 02:58 PM
s197's Avatar
I have a off road x pipe and with a hand held tuner can turn off the rear two o2 sensors so it will take that unwanted engine light off
Old Sep 30, 2012 | 07:16 PM
lime05's Avatar
I was thinking about doing the same thing. Which tuner/tune did you use?
Old Sep 30, 2012 | 11:48 PM
I would say if u want it loud like me ;D, get the off road xpipe but if u dont have money to tune it just save up for it and hold off. If u put the xpipe on without a tune it will throw annoying engine lights on and u wont have any major power gains unless its tuned for it.
Old Oct 1, 2012 | 01:11 AM
mrnickelus's Avatar
What kind of tuner you have a bama or a predator
Old Oct 1, 2012 | 01:34 AM
If your talking to me i used an sct tuner with a steeda tune.
Old Oct 1, 2012 | 10:20 AM
s197's Avatar
Sct 3
Old Oct 1, 2012 | 10:23 AM
s197's Avatar
SCT sf3/x3 is the tuner I have
Old Oct 4, 2012 | 03:53 PM
AMWill's Avatar
Former Vendor
If you don't have a tuner yet, just stick with a high flow catted Xpipe, since you will need a tuner to turn off the check engine light and honestly have your PCM dialed in correctly. Keep in mind an O/R Xpipe gets rid of a lot of restriction from deleting the catalytic converts. The free flowing exhaust will play with your fuel trims a bit, but mostly just affect the smoothness of your factory tune.
Just thought some more info would help you make your decision!
Shane
Sep 24, 2015 08:15 PM
billy y
Sep 24, 2015 11:48 AM
jwpraxis
Sep 21, 2015 08:44 PM
Bryanh24
Sep 16, 2015 08:31 PM
Sep 10, 2015 12:44 PM
