Who makes a brake upgrade (stock size)?
Hawk Performance offers ceramic brake pads and Power Slot offers slotted rotors. Check this out from tirerack.com:
http://www.tirerack.com/brakes/resul...oModClar=Coupe
[IMG]file:///C:/DOCUME%7E1/LEWISJ%7E1.JOU/LOCALS%7E1/Temp/msoclip1/01/clip_image002.gif[/IMG] http://www.tirerack.com/brakes/resul...oModClar=Coupe
You can also get them from Ninosport.com.
Slotted rotors:
http://www.ninosport.com/Mustang/Brake-Rotors
Brake Pads:
http://www.ninosport.com/Mustang/Brake-Pads
Slotted rotors:
Brake Pads:
If you want an upgrade, do pads and lines. The rotors aren't going to do jack for you, other than hurt performance. They do look cool, though.
Thanks for the advice...and humor. You are the first one to ever point that fact out to me. I have always heard that slotted and vented rotors were better. At least...that is how they are marketed.
StopTech Stage 2 brake upgrade kit from Brenspeed:
http://www.brenspeed.com/mustang_2005/brakes.html
I just installed stainless lines and R-compound pads on the car, and wow what a difference. No need for slotted/drilled rotors, the stock ones are fine. Anything else is simply cosmetic.
Don't forget to do a full high-temp fluid flush with DOT 5 or better!
If you take off your wheels, take a look at the stock rotors--they've got cooling vanes in the center. Nothing fancy looking like aftermarket stuff, but they work fine and don't cost an arm and a leg.
Meet Krissy, Our Star Racer
If you want to improve braking performance, you need better clamping power (the brake system) and better traction/grip with the road (tires).
Rotors alone won't do much unless you are serious about road course racing and they are something you are adding to an already upgraded system. The GT500 Brembo 4 piston kit I installed last year comes with normal rotors, not drilled or slotted, and they work great. This kit has proved more then I need for my driving - though I absolutely love the extra power - in fact the other day, first time ever, I heard a chirp on braking. Made me smile..
Good luck.
PS - a small wheel spacer isn't a big deal if there's a kit out there that you want but won't fit under your stock wheels. spacers are much cheaper then new wheels.
Kristina
Good luck.
Kristina
That's also worth noting--ask any serious racer at the track, they'll tell you that your tire selection will influence how well your car stops just as much as the brakes do.
Stickier tires = shorter stopping distances, but usually also increased wear/decreased tire life.
Good luck.
Kristina
Good luck.
Kristina
Thanks! I really didn't want to put a lot of money out for something that just LOOKS good. With everyones advice...I will put the money where it counts and get the results that I'm looking for. I'm surprised however, that no one spoke up to defend drilled and slotted rotors. I figured there would be at least a few. But...that only makes my choice easier. Thanks again.
If you've GOT to have one, the slotted-style are a safer bet. There have been many reports of cross-drilled rotors that have cracked because of heat expansion under heavy use. Don't know if you're planning to track your car, but this would be a major concern for me if I had the cross-drilled.
I'd like to do s.s. lines, pads, and rotors next....not to sure on how to swap out the lines without making a mess of the situation....
hags1
18' fan blades can accept Baer Eradispeed kits that increase rotor size a little and use the stock calipers with a caliper relocation bracket. Use those in conjuntion with better pads and maybe opt for a two piece rotor here as well.
I'd also stay away from cross drilled stock sized rotors as they reduce available friction surface and may be prone to cracking due to high temperature heat cycling. Slotted rotors also reduce the friction surface a little but they can aid in keeping a good clean, straight surface on the pads.
Good pads on a full surface rotor will go a long way so you don't really need slotting or cross drilling with the right pads.
Yes. I installed Brembo Cross Drilled rotors and KBC pads on my previous car and the rotors warped a bit and the pads cracked off their backings. Needless to say I went with a proper kit this time around and have been very happy (though my wheels get so filthy so quickly now).
There are rotors out there that are slotted and dimpled, for the cross drilled look. My feeling is that if they aren't CAST that way, drilling into them never produces the results you want.
Good luck!
Kristina
ps - my recollection is that the Eradispeed kit that uses stock calipers with bigger rotors costs nearly the same that I paid for my entire Brembo upgrade through Ford.
Thanks to everyone who responded. I truely appreciate you sharing your experiance. I think it is clear that drilled and slotted rotors are not a bargain. This will save me a lot of time and money.
