Who knows what this is?
Old Apr 19, 2005 | 10:20 PM
169stang's Avatar
[attachmentid=18481]
Old Apr 19, 2005 | 11:12 PM
azoufan's Avatar
That's a hydrocoil manifold pressure cylinder relief valve, and it's obviously not IN the hydrocoil manifold, rendering it useless.
DUH.
Sean
Old Apr 19, 2005 | 11:16 PM
Fazm's Avatar
Kind of looks like something out of a pushrod motor lol. what throws me off is the hole in it which looks like a cotter pin or something slides through there. It looks scraped.... so obviously you broke something lol. And what scares me, is the ring to the left of it... so tell us, whatd u break!!!
Old Apr 20, 2005 | 12:45 AM
TURBO 05's Avatar
Originally posted by Blazing Saddles@April 19, 2005, 11:52 PM
Looks like the axle retention pin. Looks like it was galled by a spider gear. Probably got some dirt on it when they changed your gearset.
I concur it is from the 8.8" rear end for sure I have seen a million of those (one of the few part still the same from the 5.0's)
Old Apr 20, 2005 | 05:00 AM
The Boss Hog's Avatar
I agree with George and Danny. It is the pin from a differential and it looks like it got a little messed up when the spider gears let go. Now let me guess why you have a picture of it . . . Did it happen to come out of a 12 second lime green Mustang
The Boss Hog
Old Apr 20, 2005 | 08:03 AM
RDSox04's Avatar
I hate when I finish putting something together and there are important looking pieces lying around. . .
Old Apr 20, 2005 | 08:09 AM
Quags's Avatar
Man, looks like corrugated cardboard with some nasty grease stains. What in the world did you do to it?! OMG.....
Old Apr 20, 2005 | 08:43 AM
MINO4.6's Avatar
Old Apr 20, 2005 | 09:48 AM
SurfnSoCal's Avatar
SO WHAT IS IT?
Old Apr 20, 2005 | 10:45 AM
Purple Hayz's Avatar
I'll tell you exactly what that is: $500-750 dollars worth of repairs, in all liklihood.....Ouch! :bang:
Old Apr 20, 2005 | 10:57 AM
manystangs's Avatar
It looks like you found out how much power a Rearend can take!
Michael
Old Apr 20, 2005 | 01:53 PM
SaleenPowr's Avatar
That's a nice muffler bearing ya got there.
Old Apr 20, 2005 | 03:12 PM
TURBO 05's Avatar
wow, i cant immagine why so much unless you killed the gears and in turn the axles too.... tell me that it isnt so...
Old Apr 20, 2005 | 04:12 PM
Sonic05's Avatar
Hmmm, looks like the dominos have started falling. You should start taking bets on what fails next.
May I suggest the Ford Racing driveshaft loops as your next mod?
Old Apr 20, 2005 | 06:29 PM
169stang's Avatar
Most of you are correct...It's hydrocoil manifold pressure cylinder relief valve. Acutally, it is the spider gear pin which is in the differential, which is in the 8.8 rearend. I've mentioned this in a couple other places here, but here's the skinny. Saturday night, after my second run, I got to the end of the track and made a left turn onto the return road (at the track). I heard a loud binding sound from the rearend. Upon disassembly, the spider gears teeth are extremely worn. That pin, above, made a few revolutions in it's slot (not supposed to do this). There is a locking pin (to the left of the main pin in the pic) that sets against the flat spot on the main pin to keep it from spinning. The locking pin is bent as well, not that you can see it that well. It looks as if the main pin was about to sheer off.? There were little cracks in the diff casing as well. After the clutch, the diff is the next weak link. I think the tranny is going to be the next "fuse." I'm just worried about running the car too hard without much of a upgraded tranny to throw in there. I'm going with an Auburn Pro diff ($450) and changing the gears from 4.10's to 4.30's. Well see.
Old Apr 21, 2005 | 06:14 PM
O5GT's Avatar
looks to me like a direct result of wheel hop.
Old Apr 21, 2005 | 06:29 PM
wild stray's Avatar
Looks like it's a good thing you live near the strip!
Old Apr 21, 2005 | 07:49 PM
169stang's Avatar
If it's from wheel hop, then it happened along time ago. I only ran maybe 3 or 4 times before the LCA's. I was on the phone the next day ordering them. It's great to live near the track!
