Where to hook up my Autometer Cobalt guage lights?
Old Jan 12, 2008 | 06:27 AM
91svtcoupe's Avatar
I am putting in my Autometer Colbalt Guages today and was wandering if anyone had them hooked into the light switch? I really don't want them on all the time with the key switch. Any help? Trying to get them in today. Thanks Rob
Old Jan 12, 2008 | 08:30 AM
gloryboy's Avatar
I mounted mine in the dash between the vents. You can use the harness feeding the info buttons. Tap into the solid yellow for your (+) positive and the solid black on the same harness for your (-) ground for the light. Using these wires will allow the gauge lights to come on and dim with the light switch.
Here is a thread from another board someone put together documenting the install.
http://www.modularfords.com/forums/s...+gauge+install
Old Jan 12, 2008 | 08:39 AM
tom281's Avatar
Since you're doing the SOS pod, just pop out the light switch panel. Reach up behind the dash and pop it out towards you or carefully pry it out from the front. You can get the illumination wire there, or do what I did and power them off of the dimmer wire so that they will dim when you dim the dashlights in the car.
Old Jan 12, 2008 | 08:49 AM
max2000jp's Avatar
That's how I did mine. I just tapped into one of the dimmer switch wires.
Old Jan 12, 2008 | 08:33 PM
91svtcoupe's Avatar
dimmer
dimmer switch sounds good...do you remember what color wire? Just trying to make it easy....I can use a test light but........I am lazy..
Anyways...thanks
oh and by the way..didn't happen today..working on another project.
Hopefulley tommorrow.
Old Jan 13, 2008 | 07:22 PM
91svtcoupe's Avatar
Got Autometer Shift light, SOS Duel Pod with Cobalt Guages installed.
I got my Autometer Colbalt Guages with the SOS Duel Pods installed today. Move the Autometer Shiftlight. What Do you think?
JonathonK
Which is Better
Nov 17, 2017 12:02 PM
RCooke08GT
Feb 19, 2017 03:03 AM
mmb0329
Oct 1, 2015 10:59 AM
Fedupdave42169
Sep 30, 2015 08:45 PM
