Where do I get springs installed?
To complete the look of my car when I put my new 18" Chrome Bullits on I am dropping the car with the Eibach Pro-Kit. Does it matter what shop I go to when I have these installed? I was gonna go to a Ford specialty shop but the 4 and 1/2 hours of labor at $89 per hour changed my mind. Also, how would I know if the rear is misaligned and how would that be fixed? Should I get a panhard bar too?
Most frontend or alignment shops will do it. Ask around for a trusted one in your area. The job is not hard at all. Should only take a shop a couple hours + alignment. If you have any auto skill at all you could do it yourself. There is a step by step how to on this site somewhere. You will only need to rent a spring compressor(you could also take the strut in hand to a shop to change the springs real quick). The rear may or may not need adjustment(panhard). Probably not. Measure tire clearance from outside edge of tire to inner fender lip.
dohc97
16
9/24/15 05:40 PM
