Wheel Repair??????
Wheel Repair??????
Ok, so I washed up my ride and took the wife to a wine festival at a nearby lake. Everything was going good until I had to park in a dirt field. The ride was a little bumby, but no major dips or holes encountered. We come home, I wake up this morning to find my right front wheel flat. I used a tire slime kit, but the tire wouldn't inflate. I took off the wheel and low and behold in the inside of my wheel was bent. Now what?
Here's some pictures of the damage. Can this be fixed?
http://i124.photobucket.com/albums/p...24/tbwv024.jpg
http://i124.photobucket.com/albums/p...24/tbwv023.jpg
http://i124.photobucket.com/albums/p...24/tbwv022.jpg
![Banghead](https://themustangsource.com/forums/images/smilies/banghead.gif)
Location: New Carlisle, Ohio (20 miles north of Dayton)
Don't fix that baby. Be on the safe side and just replace it. I would be surprised if it could be made right again. It hard to believe you didn't feel that pothole. Ouch!
Scott
Scott
I've never used them, but this place comes highly recommended:
http://www.wheeltechniques.com/wheelrepair.html
Might be worth it if you absolutely can't replace the wheel.
here's another place people have had good luck with:
www.weldcraftwheels.com
they can fix widen and narrow just about any type of wheels. i'm going to send out some 17 or 18" wheels so i can drive with the skinny's on to and from the track. the bogarts are just too fragile to drive any real distances.
Wheel Collision in Bath PA. BUT, I doubt that would hold up. If they bend that easily I'd ditch them. I personally am done with cast aftermarket wheels. I only buy forged now myself...
Where in SoCal are you? A friend of mine who lives in the Inland Empire just had his wheels repaired. Same damage as yours. The shop is local but I don't know exactly where, I'll get the number from him and get back to you.
Here you go http://www.dandbwheels.com/fs_wheel_repair.htm
They're in Montclair, the guy that does the actual work is Jason. My friend drives a Honda Accord with after market wheels. He said that his repair cost $75. Again similar damage as yours, so no repainting was required since it's on the "in" side. He also had them repair, re-finish, and repaint another wheel which was damaged on the "out" side of the wheel. I saw both wheels after the repair, it looked pretty good. BTW, I don't have any affiliation with the shop, never even been there. Just providing information that may help.
Whoops. What I typed and what I thought didn't match.
Yes, you can fix it. Take it to a professional wheel repair place and let them heat treat it and bend it back in shape. Don't go pounding away on any cast or forged wheel as they are far more brittle than cheap steel wheels.
As a side note, i've bent back steel wheels w/o problems, and didn't have any safety concerns driving on it again.
Mr. Sparkle
9/11/15 02:57 PM
robjh22
9/8/15 12:31 PM
9/8/15 10:45 AM
