wheel hopping
Old Jan 16, 2005 | 11:06 AM
O5GT's Avatar
anyone else have an insane amount of wheel hopping
had the car on the lift and the lower control arms you can flex by hand quite a bit side to side
this most likely the cause of it?
Old Jan 16, 2005 | 12:46 PM
adrenalin's Avatar
I have not experience any wheel hopping and have left quite a bit of rubber behind trying to get them to hop
Old Jan 16, 2005 | 01:07 PM
The Boss Hog's Avatar
Yes, some of us have that problem and there have been a few threads on the subject including this one.
The Boss Hog
Old Jan 16, 2005 | 01:17 PM
dhof303's Avatar
If you put wider tires on get ready, it gets worse. I got rid of wheel hop completely with a set of Steeda adjustable lower control arms with urethane bushings. I even set them at the factory length.
Old Jan 16, 2005 | 01:24 PM
O5GT's Avatar
i will have the steedas here monday or tuesday, looks like an easy install
the shifter looks like a pita, its still sitting on my tool box...
Old Jan 16, 2005 | 02:12 PM
dhof303's Avatar
The shifter is not as bad as you might think. I would compare the difficulty of both about equal and I have put both on my car. Both also provide equally satisfying results, and I am a firm believer in spending money on horsepower first not necessarily these items.
Old Jan 16, 2005 | 05:16 PM
joeuser42's Avatar
Since you left them at the factory length and got rid of the wheel hop, I wonder if just replacing the bushings on the factory arms would eliminate it. I didn't have wheel hop until I had the 4.10s installed and I'd like to get rid of it as cheaply as possible.
Old Jan 16, 2005 | 05:48 PM
169stang's Avatar
I will be getting the Steeda set as well as the upper 3rd link which they will have in 2 weeks. This will remove the torquing (sp?) or twisting on the rear axle, which is causing it to hop. Before I discussed this with those here (Boss Hog etc.), I spoke with Steeda and between the control arm and upper 3rd link, the hop is pretty much removeable.
Old Jan 16, 2005 | 05:57 PM
169Stang,
I was under Ruby today ( ) looking at that upper arm. The rubber bushings at both ends of it look big and soft. I'm sure it is moving around quite a bit. BMR's upper arm won't be available until the 1st of Febuary.
The Boss Hog
Old Jan 16, 2005 | 06:01 PM
169stang's Avatar
Steeda's response:
The control arms are causing wheel hop in your car. With such a soft bushing set up and flexing, our Billet Lower Control Arms will really help fix this. We will also have a correct upper Third Link Arm in a couple weeks.
Mike
I just think you're on the mark Mr. Hog. haha
Why did you go with BMR, if you don't mind me asking? Steeda has their's in Billet, not that anyone would see them. Do you see the red at all on your's? I think BMR has their's in black as well-don't know.
Old Jan 16, 2005 | 07:57 PM
swingle007's Avatar
I must just be lucky as heck....I've never had any hop and I've even gone to the 4.10's and the 275's in the rear....weird that everyone else has at least some, and it supposedly should be worse with my mods....
John
Old Jan 16, 2005 | 09:01 PM
169stang's Avatar
I don't understand it either. Maybe those having the hopping issue have more power than you. Just kidding! I really have no idea. When you feel like your teeth fillings are being shaken out, you'll know you have wheel hop. Maybe it has to do with temperature, humidity, type of ashalt? All I know is that I need to make changes to remove the wheel hop I experience. Believe me, I'd rather not spend the money and time.
Old Jan 16, 2005 | 09:10 PM
Madhouse's Avatar
Depending on the road surface, and how much I get into it, I may or may not get wheel hop. I've done a bunch of smoking launches with no issue, then again I've had the rear hop so I got out of the gas. I'm sure it's a traction thing, more hop in the stickier conditions.
Old Jan 16, 2005 | 09:38 PM
169stang's Avatar
I agree. I don't always get hop on the street. The 2 times I ran at the track, I lost a tooth filling!
Old Jan 16, 2005 | 10:32 PM
O5GT's Avatar
my radar detector popped off the windshield mine hopped so bad
Old Jan 16, 2005 | 10:52 PM
Eric R's Avatar
While sad, you must admit that is funny to read!
Old Jan 17, 2005 | 04:59 AM
I went with BMR because they offered an arm with the poly bushing at one end and a helm joint at the other. Steeda did not. The way I figured it, two poly bushings would not be enough and two helm joints would be too much. Then again, I may have had too many beers when I came to that conclusion . I don't think there is anything wrong with either company's product and either will be a vast improvement over stock. BTW I went with the black.
The Boss Hog . . . . . who turned the heater off?
Old Jan 17, 2005 | 05:04 AM
John
John,
I don't really remember but is your car an automatic? If so, maybe that is the difference in the wheel hop situation. Your torque converter may not be hitting the axle as suddenly as a clutch. Just an idea.
The Boss Hog
Old Jan 17, 2005 | 07:00 AM
SixtySix's Avatar
I think you got it on the money Boss, I bet if he or I would do a neutral drop we'd get it too!
(We're both automatics)
(The idea of doing a neutral drop launch sends shivers down my spine!)
Old Jan 17, 2005 | 09:19 AM
RRRoamer's Avatar
Oh, come on SixtySix!!! Your auto is a constant mesh transmission! The only thing that happens when you drop it into gear is a few clutchs and brakes tighten up. What can it hurt if you are already at 5500 rpm when you slide it into gear???
