What To Do Next??!!
What To Do Next??!!
Alright, as you can see in my sig, right now I have cai/tune, mufflers, JBA longtubes with catted H pipe, and a Hurst shifter. I plan on going FI, so I am not planning on UDP's. If I got CMDP's, would I be able to use them with a supercharger? Other than those, what do you all recommend for me to do next. I do not go to the track much, just like to know I have the power under my belt.
Thanks all!
![Icon Mrgreen](https://themustangsource.com/forums/images/smilies/icon_mrgreen.gif)
Suspension, braces and Brakes.
I have the same questions. What next??
First I think I'm going to remove that front radiator support. So far, it seems that it is 40 lbs. of nothing needed, from what I''ve been reading.
Sooo, that will be my next venture. Just bought my driveshaft loops. but that is a quick and easy install. Top and bottom strut braces to follow that. Then I'll start with that support.
Yes you can use delete plates with a blower, turbo, or nitrous. Or you can do gears for around $500 installed; its a great mod. If I were you though, at this point, I'd just save for the blower. That'd be your best bet.....
you can use CMDP's with fi, thats actually where it's an important mod, but if you go with a twin screw sc, it will come with a new intake that already has the plates deleted..........If you go turbo or centri you will need them.......Next mod for your driving style should be a twin screw........imho.......start the fund........
