What To Do Next??!!
Old Jan 5, 2008 | 01:25 PM
officespace56's Avatar
What To Do Next??!!
Alright, as you can see in my sig, right now I have cai/tune, mufflers, JBA longtubes with catted H pipe, and a Hurst shifter. I plan on going FI, so I am not planning on UDP's. If I got CMDP's, would I be able to use them with a supercharger? Other than those, what do you all recommend for me to do next. I do not go to the track much, just like to know I have the power under my belt. Thanks all!
Old Jan 5, 2008 | 01:41 PM
FLAstangx3's Avatar
Suspension, braces and Brakes.
I have the same questions. What next??
First I think I'm going to remove that front radiator support. So far, it seems that it is 40 lbs. of nothing needed, from what I''ve been reading.
Sooo, that will be my next venture. Just bought my driveshaft loops. but that is a quick and easy install. Top and bottom strut braces to follow that. Then I'll start with that support.
Old Jan 5, 2008 | 02:02 PM
tom281's Avatar
Yes you can use delete plates with a blower, turbo, or nitrous. Or you can do gears for around $500 installed; its a great mod. If I were you though, at this point, I'd just save for the blower. That'd be your best bet.....
Old Jan 5, 2008 | 03:19 PM
gloryboy's Avatar
you can use CMDP's with fi, thats actually where it's an important mod, but if you go with a twin screw sc, it will come with a new intake that already has the plates deleted..........If you go turbo or centri you will need them.......Next mod for your driving style should be a twin screw........imho.......start the fund........
Old Jan 5, 2008 | 04:16 PM
LEO_06GT's Avatar
Driveshaft or Gears.
Old Jan 5, 2008 | 04:59 PM
SONICBOOST's Avatar
I would get some LCA's...
Old Jan 5, 2008 | 09:43 PM
JonCo's Avatar
LCA's and Gears
Old Jan 5, 2008 | 09:45 PM
Torrence's Avatar
Gears and suspension.
