What are the differences in these two exhaust syst
Old Mar 31, 2005 | 08:02 PM
chorpeac's Avatar
Magna flow Axlebacks, and the Flowmasters of the same type.
What's the difference?
Old Apr 1, 2005 | 07:56 AM
tx2005gt's Avatar
i have the flomaster kit on my 05. the sound is great. there is a drone when you are in 5th gear at low rpm. here is a grood review on them.
http://www.fordmuscle.com/archives/2005/03...flers/index.php
Old Apr 1, 2005 | 08:20 AM
2005RedGT's Avatar
Flowermasters are a chanmbered mufflers. Basically the exchayst and sound go thru doors/maze to get out of the muffler.
The Magnaflow are straight thru pipe with tiny holes that send some sound & exhaust into the holes. In the area behind the holes is sound deading material to lower the volume of the sound.
I hope this helps.
-Bryan
Old Apr 1, 2005 | 09:56 AM
chorpeac's Avatar
OK so they produce different sound. How would you describe the sound for these two?
Oh yeah, and what is this drone? What does that sound like?
Old Apr 1, 2005 | 11:29 AM
96vert's Avatar
Try mustangexhaust.com. Register and listen to the sounds in the 4.6 section.
I don't know how to explain it other than flowmaster is more of a classic muscle car sound and magnaflow / bassani (all "straight through" styles) are more of an exotic sound.
My personal favorite is JBA, followed by MAC and Flowmaster (similar sounds). Check out THIS sound clip for an example of a JBA muffler system.
You should be able to find flowmaster clips on the flowmaster website, jba clips on the jba website, etc...
Edit: and drone is a resonance sound inside the cabin at certain rpm ranges (generally between 1900 and 2300 RPM, depending on which muffler system you're talking about. It basically just sounds like it gets real loud at certain rpms (but only inside the car, not outside the car).
Old Apr 1, 2005 | 12:20 PM
JohnnyZ's Avatar
I like the Magna flow
Old Apr 1, 2005 | 12:26 PM
Blow-By Racing's Avatar
On the 05 Mustang the MagnaPak mufflers sound really good w/ stock h-pipe. If you plan on running and offroad xpipe it might be a bit loud. The flowmaster sound about the same as it did on th 04 gt's, but the magna flow sounds good on the 05- It is what we are installing the most of on our 05 customer cars.
OU r website should be up in about a 1 or 2 and we will have sound clip for the 2005 mustang exhaust section...
Old Apr 1, 2005 | 12:55 PM
chorpeac's Avatar
Those JBA's sounded good. I want to keep the deep rumble, but I don't want it to be so loud that I get kicked out of my neighborhood. Hahaha. SO I think I will stick with the stock h-pipe, but then which gives a more deep throaty rumble the flowmasters, magna flows, JBA??
Old Apr 1, 2005 | 05:39 PM
j-stang's Avatar
I had the Magnaflows - thought they sounded just a little deeper than stock.
changed to Magnapacks TODAY and I love them - not terribly loud but difinitely a nice rumble; however, the drone inside the cab is much louder around 2000 rpm. Can't wait until I put on my CAI - then it will rumble more.
Good Luck!
PS - I might have some Magnaflow axlebacks for sale (less than 500 miles on them).
Old Apr 2, 2005 | 06:30 AM
Ranger's Avatar
Have the Magnaflow axle-backs. Can't comment on the Flowmasters. The Magnaflows, compared to stock, are a little louder and definitely more deeper "throat" sounding. Drone is not a problem and I do alot of highway driving.
Old Apr 12, 2005 | 05:09 PM
vincesandlin's Avatar
tx2005gt
good info
thanks
Old Apr 13, 2005 | 12:06 PM
budgreen3564's Avatar
had the flowmasters on the wife's gt and changed them for bassani. flowmasters create a lot of cabin drone
Sep 10, 2015 12:44 PM
robjh22
Sep 8, 2015 12:31 PM
whowasthat
Sep 3, 2015 08:48 PM
