Weight Reduction Tips?
Old Jul 31, 2007 | 10:31 AM
bored out's Avatar
Any good weight reduction tips for someone who wants to keep the stock exterior / interior look? What can we remove or change that would lower the weight but keep a stock appearance?
Old Jul 31, 2007 | 10:38 AM
Lowe!'s Avatar
Here are some of the obvious things:
- Spare tire, jack, etc.
- 1 piece driveshaft / lightweight flywheel (what is it, 1# roatating mass = 10#s dead weight?)
- Aftermarket K-member
- Lightweight wheels/tires/brake rotors if you're going that far
Old Jul 31, 2007 | 12:19 PM
don_w's Avatar
Also, tubular radiator support/swaybar delete and A-arms.
Old Jul 31, 2007 | 12:21 PM
don_w's Avatar
FWIW, they had a scale set up at the track on Saturday night, so I got a chance to get my car weighed in track trim. It weighed in at 3547 pounds w/o driver. As I figured, it's just under 3800lbs with my 238lb butt in it.
It also seems to be a little front heavy... 54.9% front, 45.1% rear. The breakdown per wheel was:
LF=983, RF = 963
LR = 804, RR = 797
Old Jul 31, 2007 | 12:33 PM
blkstang06's Avatar
LF=983, RF = 963
LR = 804, RR = 797
Good post, Don! have you thought about Jenny Craig!........
Old Jul 31, 2007 | 01:16 PM
don_w's Avatar
When I think about Jenny Craig, I get this visual image...
Old Jul 31, 2007 | 06:01 PM
281GT's Avatar
Hey Don aren't you using a cast iron block in there? That would partly explain why your weight distribution is worse than stock. The super charger would make up the rest as it's all weight up front. Still not too bad though.
Old Jul 31, 2007 | 06:06 PM
70MACH1OWNER's Avatar
LF=983, RF = 963
LR = 804, RR = 797
We are in the same weight class there Don. You can change your weight ratio if you just move the drivers seat to rear as far as it will go!!
Scott
Old Jul 31, 2007 | 06:18 PM
don_w's Avatar
No, it's an aluminum Teksid block. It's only a few pounds heavier than a stock 3V block. And in addition to the SC, I also have a shaker scoop, and an oversized I/C reservoir where the factory airbox used to be. It probably holds at least 20lbs of water.
Scott
I already do that... that's the only way my legs fit in there. haha
CiniZter
25
Apr 28, 2016 05:41 PM
Sep 10, 2015 12:44 PM
Sep 8, 2015 10:45 AM
earl610
Sep 6, 2015 05:48 PM
Kestral
Sep 5, 2015 11:50 PM
