Ways to improve traction
Old Mar 28, 2005 | 02:22 PM
zwooky's Avatar
I know next to nothing about suspension but I am wanting to improve my traction on takeoff. There is so many parts (springs, trailing arms, panhard bars, swaybars, etc) and I'm not sure what they do. I'm looking to get better traction on takeoff. I don't really care about cornering better or anything else, just takeoffs. Thanks for any info!
Old Mar 28, 2005 | 02:59 PM
169stang's Avatar
As far as I know...lower control arms, upper third link, and a set of Mickey Thompson (they hook the best). I think it was JDP that just announced an adjustable shock. The shocks are pricey. I'm sticking with the items mentioned above except the shocks.
Old Mar 28, 2005 | 03:35 PM
MTAS's Avatar
Mr. 169stang knows what he's talking about, for sure. I have the BMR tubular LCA's and they completely eliminated wheel hop. I don't race so that will most likely be the only suspension mod I do.
Old Mar 28, 2005 | 03:43 PM
SurfnSoCal's Avatar
where did you purchase the BMR's?
Old Mar 28, 2005 | 03:49 PM
MTAS's Avatar
I think they have on-line ordering at their site at http://www.bmrfabrication.com. I got them at FFW in Orlando at the beginning of March.
Old Mar 28, 2005 | 04:04 PM
SurfnSoCal's Avatar
great..their site is down....sigh....I am just going to wait a bit for Maximum Motorsports to come out with something.
Old Mar 28, 2005 | 04:38 PM
169stang's Avatar
I bought the Steeda Billet lower control arms. They are a bit pricey, but work great! Got them from Steeda direct.
Old Mar 28, 2005 | 05:29 PM
MTAS's Avatar
It's back up and here is their on-line ordering site.
Old Apr 4, 2005 | 09:14 PM
Mongoose's Avatar
Originally posted by MTAS+March 28, 2005, 4:52 PM--><div class='quotetop'>QUOTE(MTAS @ March 28, 2005, 4:52 PM)</div><div class='quotemain'><!--QuoteBegin-SurfnSoCal@March 28, 2005, 5:46 PM
[/b][/quote]
I have these and they do the job at a reduced cost. You do not need adjustable ones.
Old Apr 4, 2005 | 09:17 PM
Mongoose's Avatar
[/b][/quote]
Old Apr 4, 2005 | 09:36 PM
169stang's Avatar
I have to revise what I stated above! REDO!
LCA's, upper third link, sticky tires, lower the car 1", and coil overs.
I have the first 3, and will be getting the car lowered tomorrow with Steeda springs. Once the coil overs are available, I'll be getting them. I do have a new RAM clutch and I can't stick to the track when shifting. My shifting technique is partly to blame, but lowering the car and stiffening the rear will help keep the car more level and less of the teeter-totering effect. If you look at most novice videos or live(including myself), you will see this. Most experienced drivers shift alot faster and smoother. From what I've learned from experienced racers at the track and my mechanic/veteran drag racer is that keeping the motion forward is better. If your suspension is stock or loose, when you launch; the front end moves up, out of gear, moves down, into gear, moves up. This is a loss of forward motion. Picture launching and the front end moving up. This is good because you're throwing all the weight to the rear tires-better traction. You want to "squat" the rear and load the front suspension. If you can keep the nose from coming down so fast and keep the car moving towards the end of the track---ideal! The way my clutch engages-hard, when I shift, the front end comes down, clutch hits hard thus throwing the front end up again and loading the rear suspension=loss of traction. I'm doing this in EVERY single gear-including 4th. I will be moving my rev limiter up so I can keep it in 3rd crossing the 1/4. Hope this sheds light to some here. It's taken me quite a few passes and 4 months to really see this. No one-including myself, can really appreciate the skills needed to drive fast (in respect to 1/4 mile) until your behind the wheel doing it. Initially, I thought, how hard could it be? When you actually get all the HP to the rear wheels, it's a new ball game. I had all the mods listed in my sig, but when I put the RAM clutch in, upper 3rd link...everything changed. That was the turning point for me. My car requires more skill to drive it to it's fullest potential! Just trying to save some learning for others. This is just my window looking out.
Old Apr 4, 2005 | 10:09 PM
dhof303's Avatar
David, I couldn't agree with you more. After installing the lower and upper adjustable control arms my car has become a handful to drive on the street. I feel the rear planting solidly and the car wants to move straight forward but wheel spin happens much easier and is difficult to avoid at any RPM and with the first three gears. I am looking into shocks after I put in my Steeda lowering springs.
Old Apr 4, 2005 | 11:15 PM
169stang's Avatar
eye to eye brother!
robjh22
Dec 14, 2015 08:41 AM
tukatz
Off-Topic Chatter
23
Oct 20, 2015 09:54 AM
Sep 10, 2015 12:44 PM
Sep 8, 2015 10:45 AM
