Vortech Help
Vortech Help
I have the Vortech HO kit with Heat Exchanger on my 05 GT.The Coolant Recovery tank that Vortech Supplys is Plastic and is mounted on the Passenger side Shock tower.That tank cracked at the seam,so I bought another one from Vortech.My Question is has any one had this Problem and should I start looking for somone that will build a metel or Aluminum one.Thanks Driver
you could try buying a canton trank or ask if they could make you one. i know i am going to ask if they can make one for the whipple since they decided last min to convert to a factory type plastic one.
9/16/15 06:44 PM
