Vortech Help
Old Jun 23, 2007 | 10:28 AM
Driver's Avatar
Vortech Help
I have the Vortech HO kit with Heat Exchanger on my 05 GT.The Coolant Recovery tank that Vortech Supplys is Plastic and is mounted on the Passenger side Shock tower.That tank cracked at the seam,so I bought another one from Vortech.My Question is has any one had this Problem and should I start looking for somone that will build a metel or Aluminum one.Thanks Driver
Old Jun 23, 2007 | 05:24 PM
SONICBOOST's Avatar
I don't know man but you could update ur sig!
Old Jun 23, 2007 | 05:51 PM
Driver's Avatar
OK Adam I was told untill I posted X times I would be a V6 Member. If that is not True how do I change It ADAM
Old Jun 23, 2007 | 06:38 PM
RedDragon777's Avatar
you could try buying a canton trank or ask if they could make you one. i know i am going to ask if they can make one for the whipple since they decided last min to convert to a factory type plastic one.
Old Jun 25, 2007 | 04:56 PM
ken3030's Avatar
My plastic paxton one leaks too it expands way too much. I think they are a problem.
Old Jun 29, 2007 | 05:24 AM
Driver's Avatar
Thanks Gang,I will get one made at the local fab shop. Thanks
MustangGTCS13
Sep 17, 2015 07:38 AM
Sep 16, 2015 06:44 PM
TK421
18
May 19, 2005 08:27 AM
Greywolf
Aftermarket 2005+ Mustangs
Nov 4, 2004 04:53 PM
