Underhood Mod questions...
I am getting ready to do a major overhaul on my Mustang and had a few questions...
What U/D pulleys to get? BBK or Steeda? Any differences???
Which Delete Plates to get? Economy or Charge Motion Control Plates???
Anyone have a recommended Throttle Body for the S197's? I had a BBK for a little while, but it fail safed on me one day, and I returned it for my money back shortly thereafter. I would like to try one again though, as I really liked the throttle response it gave me.
I think that's about it for now. Will add on to this, if I have any other questions.
Thanks!
Thanks!
Thanks!
Thanks!
Steeda UDP
Get the Steeda billet CMDP. Their bored out .07 over stock. You'll lose some low end torque with these those(correct me if I'm wrong)
Don't bother with a throttle body. Do gears instead or something. You can spend your money else where or just save it. Unless your doing some crazy HP numbers the stock one is perfectly fine.
In my opinion:
Steeda UDP
Steeda UDP
I don't do trannies
or rear-ends anymore!
Don't waist your money on a TB until/if you go f/i a good/custom tune will do the same thing
And +1 for BBK pullies
I've had my Steeda Pulleys for well over 2 years, and haven't experienced any problems whatsoever. I also gained 10 RWHP on the dyno as well.
In my opinion:
Steeda UDP
Steeda UDP
I believe the econo plates are the same size as the stocker, but with the butterflies removed. I have not noticed an loss what-so-ever down low in the torque or hp categories.
