Underhood Mod questions...
Old Oct 8, 2008 | 05:06 PM
CrazyGreek89's Avatar
I am getting ready to do a major overhaul on my Mustang and had a few questions...
What U/D pulleys to get? BBK or Steeda? Any differences???
Which Delete Plates to get? Economy or Charge Motion Control Plates???
Anyone have a recommended Throttle Body for the S197's? I had a BBK for a little while, but it fail safed on me one day, and I returned it for my money back shortly thereafter. I would like to try one again though, as I really liked the throttle response it gave me.
I think that's about it for now. Will add on to this, if I have any other questions.
Thanks!
Old Oct 8, 2008 | 05:59 PM
travelers's Avatar
I went with Steeda pulleys and the econo plates. do you really think you need a bigger throttle body? If so then I would go with the GT500 if any.
Old Oct 8, 2008 | 06:02 PM
JonCo's Avatar
Thanks!
In my opinion:
Steeda UDP
Get the Steeda billet CMDP. Their bored out .07 over stock. You'll lose some low end torque with these those(correct me if I'm wrong)
Don't bother with a throttle body. Do gears instead or something. You can spend your money else where or just save it. Unless your doing some crazy HP numbers the stock one is perfectly fine.
Old Oct 8, 2008 | 06:59 PM
karman's Avatar
Originally Posted by JonCo
In my opinion:
Steeda UDP
Yeah, what he said.
Old Oct 8, 2008 | 07:04 PM
EagleStroker's Avatar
I don't do trannies
or rear-ends anymore!
Don't waist your money on a TB until/if you go f/i a good/custom tune will do the same thing
And +1 for BBK pullies
Old Oct 8, 2008 | 07:09 PM
officespace56's Avatar
Steeda Pullies, Economy Plates.
Old Oct 8, 2008 | 08:50 PM
don_w's Avatar
+1000... the stock TB worked fine for me all the way up to 12 psi boost. Only above that did it become a restriction.
Old Oct 11, 2008 | 02:54 AM
m05fastbackGT's Avatar
I've had my Steeda Pulleys for well over 2 years, and haven't experienced any problems whatsoever. I also gained 10 RWHP on the dyno as well.
Old Oct 11, 2008 | 11:13 AM
In my opinion:
Steeda UDP
So...do the economy plates have low-end torque loss as well? If anything, I want to gain horsepower and torque. That's why I am also contemplating the FRPP Hot Rod Cams until I see a dyno of those!
Old Oct 11, 2008 | 01:17 PM
I believe the econo plates are the same size as the stocker, but with the butterflies removed. I have not noticed an loss what-so-ever down low in the torque or hp categories.
TripleBlack14
May 10, 2016 04:30 AM
Bryanh24
Oct 14, 2015 08:43 AM
