Underdrive Pulley !!!
Old 2/16/07 | 10:50 AM
2006muzzy's Avatar
Many of the us over at "ponies on the run" are condsidering installing a underdrive pulley. I have the Roush pulley sitting in my trunk but nervous getting it put in hearing so many stories of other systems acting up do to the underdrive pulley.
NEED FEEDBACK FROM PULLEY OWNERS BEFORE I INSTALL
THANKS
Old 2/16/07 | 10:54 AM
TillmanSpeed's Avatar
Former Vendor
I've had no problems ever with the Steeda underdrive pulley set (water pump and harmonic balancer). That's what I would go with, unless you're set on the Roush brand. I have a deal for 192.99 shipped to the door on these pulleys.
http://forums.bradbarnett.net/showthread.php?t=60521
CR
Tillman Speed
Old 2/16/07 | 11:11 AM
2006muzzy's Avatar
CR
Tillman Speed
thsnks, but I already have the pulley in the trunk of my car.
Old 2/16/07 | 11:38 AM
freebass55's Avatar
Just one pulley??? Or do you have the set?
Old 2/16/07 | 11:45 AM
Former Vendor
That's what I'm trying to understand. Just the roush crank pulley only, or water pump pulley only?
Old 2/16/07 | 11:51 AM
hags1's Avatar
While your in there you might as well do the water pump as well and get all the gains possible....Breenspeed has the water pump and pulley combo for a good deal....and max. gains in that area.
hags1
Old 2/16/07 | 11:52 AM
2006muzzy's Avatar
I have the 1 pulley
1 crank pulley do i need both?? Will I notice the HP gain??
Old 2/16/07 | 12:24 PM
Former Vendor
It is reccommended to do both. They work in conjunction with each other. Yes you will notice the difference in HP gains. The Steeda UDP set is 192.99 shipped to the door from us. Let me know if you have any questions!
CR
Tillman Speed
Old 2/16/07 | 12:50 PM
SteelTownStang's Avatar
Hey CR... What do you charge for the install? Also, do you install gears?
Old 2/16/07 | 12:56 PM
Former Vendor
The install for both the UDP's and Gears are like 450-500 bucks. That's fully set up with gear oil and everything.
CR
Tillman Speed
Old 2/16/07 | 01:45 PM
05BlackGT's Avatar
I've used the Steeda pulleys on my last three mustangs without any issues. Installed myself with help from dad.
Old 2/16/07 | 09:58 PM
Northwest GT's Avatar
Same here. Had them in my '96 and now in my '05 (Steeda). UD pulleys should give you no cooling or electrical (charging) problems. If you do have such problems, the fault is probably not with the pulleys. It's a good mod for the price, but don't expect miracles. It might net you a few extra ponies.
Old 2/18/07 | 10:39 PM
odiaz's Avatar
Go for it, install the UDPS, you won't regret it. I've had mine on for 18 months. It took me a long time the first time I did it but I learned from my mistakes and the second time, it only took about 2 hours. I wrote up instructions on how to do it so others could learn from my mistakes.
Here are my instructions:
http://www.cherod.com/mustang/HowTo/Pulleys.htm
Old 2/18/07 | 11:50 PM
heyitsben5's Avatar
yea man totally go for I have had it in my 06 stang for 8 months with no problems
Old 2/21/07 | 09:34 PM
SoFlaBoss's Avatar
Duplicate posting. Moderators - please delete.
Old 2/21/07 | 09:37 PM
SoFlaBoss's Avatar
SoFlaBoss's Avatar
I finally got around to installing my Steeda UDPs yesterday, considering I bought them over a year ago. Thanks to Odiaz' write-up, the install was so easy, especially being able to pickup the right harmonic balancer puller from Autozone. And the trick to use the rubber band on the puller worked perfect. After reading all the trouble people were having trying to remove the harmonic balancer bolt, I wasn't looking forward to that part. When it came time to remove "the bolt", it couldn't have been easier. I did it by putting the car in 5th gear, setting the emergency brake, and used the breaker bar with floor jack handle technique. There was also no need to put the car on stands or remove the radiator fan assembly. After popping off my C&L CAI, there was plenty of room. The whole operation took me less than 2 hours.
Old 2/22/07 | 12:35 PM
another 06gt's Avatar
After the install do you need a new tune for them to work right???
Thanks Saverio
Old 2/22/07 | 12:39 PM
Former Vendor
http://forums.bradbarnett.net/showthread.php?t=61066
If anyone needs a good deal on pulleys, there's your chance!
CR
Tillman Speed
Old 2/22/07 | 04:19 PM
jayguy's Avatar
another 06gt, no tune is needed.
