UDP install and CEL P0113???
After installing Steeda's underdrive pullies (crank and water pump), I'm getting an intermittent CEL. When the light stays on, I can pull "P0113 Intk AR TMP CIR HI IN", sometimes it just flickers and no code is stored.
I suspect the MAF or MAF connector, but any ideas appreciated.
John
John
· P0113 Intake Air Temperature Circuit High Input
In addition to what Rick suggested, disconnect your battery and disconnect all your electrical connections that you removed for the UPD install and check for pin damage, then reconnect. Then reconnect your battery and check the system out for any CEL's.
Good luck!
Good luck!
It's getting worse: let me start over.
On Saturday my son (a mechanic) installed Steeda underdrive pullies. The C&L intake tube was removed, the power steering and rad fluid reservoir put aside, and the fan removed to make room per the instructions.
On the way home after work, after reaching operating temp (maybe 8 miles), he got a CEL which the xcal showed to be a P0113, the intake temp sensor voltage high. We disconnected/reconnected the MAF connector, and took it out around the block again. The CEL flickered on and off, but didn't store a code. Ok, it seemed like the connector. We disconnected/reconnected again, and all seemed well.
Sunday, the car went out again after a brief warmup. After reaching normal operating temp (190 degrees) the CEL came on and stayed lit. Three new codes were thrown:
p0300 rndm mult cy msfr det
p0301 falt cy a msfr det cy 1
p0306 falt cy g msfr det cy 6.
Tomorrow, we're going to work backwards and remove everything again (well, not the pullies--yet), spray the MAF with throttle body cleaner, and then reassemble. But does anyone have any other ideas on where to look or attempt a diagnosis? Crankshaft position sensor damaged, maybe?
mods are in my signature...
· P0301 Cylinder 1 Misfire Detected
· P0306 Cylinder 6 Misfire Detected
Only 2 electrical plugs were disconnected, right? (MAF and the elect. fan)
Try and disconnect the battery for a few mins, then re-flash your tune?
Crankcase breather off the C&L tube connected okay?
Just thowing out ideas...
· P0300 Random/Multiple Cylinder Misfire Detected
I hate this "what-should-be-simple-but-is-becoming-a-major-pain-in-the-a$$", but that's the price we pay!!
John
If this is not the problem, re torque the crank bolt. If this is not torqued correctly it will throw that CEL because the timing wheel behind the front cover is able to vibrate.
Ken
There is about a 90% chance the crank pulley wasn't installed right. I see this all the time at the shop. The UDPs come with a longer bolt to start the pulley with. Sometimes people don't read the directions and just use that bolt and leave it in. If this is the case, remove and install correct bolt. With the longer bolt, the crank pulley is not on far enough.
Ken
Ken
Thanks I'll keep you posted.
John
We're letting it sit for a few hours to work on the '87 Mustang, then will take it out for a longer cruise to see what happens. I'm still buying 2 crankbolts and if the same CELs come up, will use a new bolt and retorque per instructions again, and if THAT doesn't fix it, then put the original pullies back in and see what happens.
Thanks for the quick feedback everyone, more as I know it.
John
Thanks for the suggestion.
John
9/10/15 12:44 PM
