Turn Signal Blinking Fast
Old Mar 28, 2005 | 09:16 PM
Dan's Avatar
Dan
Do You Remember Me?
My left turn signal is blinking at about 2x the normal rate. Both front and rear lights work and are also blinking twice as fast.
Any suggestions as to what the problem is? (ie. the stock is broken?)
Thanks,
Dan
Old Mar 28, 2005 | 09:27 PM
oatmeal's Avatar
I believe this issue is normally a blown fuse. I haven't even looked at the fuse panel, but I am sure you can search on the net for what fuses do what... and then check to make sure they are in good shape.
Old Mar 28, 2005 | 09:44 PM
Dan's Avatar
Dan
Do You Remember Me?
Thanks steven, that was the first thing I was going to check tomorrow morning.
Old Mar 29, 2005 | 06:00 PM
RRRoamer's Avatar
Usually, the blinker blinks faster when you have a blown bulb. Originally, the analog blinker circuit was designed this way to provide the driver with an indication of a blow bulb. I would not be surprised to find that the electronic version has been designed to mimic this behavior. Check your bulbs...
lakersfreak
Jun 13, 2022 12:29 AM
ricky1728
Feb 11, 2016 07:25 PM
boz
Oct 1, 2015 04:47 PM
