Tuning
Originally posted by BigWorm2005GT@May 13, 2005, 6:52 PM
Danny,
What exactly is the difficulty you're experiencing? You can't download the tune from the website to your PC, or from your PC into the Predator?
Danny,
You have the DSDownloader application? Then all you need to do is plug the Predator into the PC with a standard DB9 male to DB9 female serial cable, and have the proper AC power supply. After that, just follow the on-screen prompts and the instructions from the website for DSDownloader.
What error, if any, is it giving you?
Originally posted by DANNY@May 13, 2005, 7:27 PM
Cannot load C&L -05 application into stang-05 tool.
Hi,
Do you have a Diablo Predator or a C&L one? It will boot with the Diablo logo if it's Diablo and so forth...I bought my computer cord and power adapter from Radio Shack, as specified in the manual. Also, use the latest 1.26 downloader software. Make sure and reboot after you install, and you should only have the tune, and the original backup file in a folder within the Diablo folder called: "ori files". This method worked for me. PM me, and I can help you with more detail if you need it. Hope this helps!
Somewhatdamaged
Originally posted by somewhatdamaged@May 13, 2005, 8:27 PM
Hi,
Somewhatdamaged
Hi,
Somewhatdamaged
Hi,
Somewhatdamaged
Hi,
Somewhatdamaged
Danny,
Check and make sure you have a Predator model U7140, which I think you do. If so, go HERE. You'll need to know the 7 character CALID from your car to download the right file. The webpage above is self-explanatory. See if that works.
