Tune help after header install?
Old Oct 10, 2010 | 01:58 PM
d_bone33's Avatar
Hey, last weekend i put some JBA longtube headers....and then i bought a jbb short H pipe..and then put magnafow exaust on it....no my question is. do i need to get an email tune after i have done that to add to the other mods i put on..i get them free from SCT....does anyone know if i should call them and get a tune update?
Old Oct 10, 2010 | 02:08 PM
David Young's Avatar
I'm no expert on tunes but i would say 'yes'. Your fuel and air mixture is going to be messed up. I got a 'no tune' C&L c.a.i. but i know i will have to have my tune changed when i add shorty headers when and if anyone ever makes some for the 2011 V-6.
Old Oct 10, 2010 | 06:19 PM
While it may run within the stock ECM's parameters, if you want the most out of your performance investment (and hard work putting those headers in), you want a tune.
Old Oct 14, 2010 | 07:16 AM
JScottGT's Avatar
You will want the tune to be updated. When using LT's, you end up moving the oxygen sensor further downstream. The ECU will be seeing different values coming from the sensor that it will be expecting, and that could cause some issues with idle as well as low-speed driving (when it's in closed-loop mode). Whoever is doing your tune will have to add in an "offset" value to account for the moved O2.
drmag
Sep 1, 2015 03:47 PM
DarrenGT
Aug 19, 2015 08:22 AM
Bullitt 3309
Aug 2, 2015 10:20 PM
Vader99
Jul 19, 2015 08:19 PM
