Traction Control Button
Old 12/25/07, 08:20 PM
Steved's Avatar
Is the traction control button a momentary contact? The Haynes repair manual show it as a SIG wire. I suppose that means signal. If so I'll install a circuit that waits until start +10 or 15 seconds then pulses the signal wire for a second and goes away. This would be a simple auto Off mod and leave TC operable.
The tuners can turn off TC but then you can't turn it back on and you get errors in the info display.
I was under full boost the other day when TC decided to pull the fuel.... Bad bad bad.... I know, I know, I freaking forgot
I'd rather look out the window "Oh its raining turn the TC On" But then again if it's raining I wouldn't be under full boost......
Or better yet can you program the GT 500 TC program into a GT?
Old 12/25/07, 09:20 PM
hammeron's Avatar
i think it's a great idea.
i'm not sure whether the switch is
momentary or not, even after
looking at a wiring guide.
if you do build the device, please
let us know
Old 12/26/07, 06:02 AM
05YellowGT's Avatar
Ditto on letting us know ... I getting pretty good at remembering to turn it off every time I start the car , but it would be nice for an automatic feature like this ...
Old 12/26/07, 06:47 AM
tom281's Avatar
I believe it is a momentary switch.....
I didn't think that it pulled fuel though when it kicks on..... are you sure about that?
Old 12/26/07, 07:39 AM
theedge67's Avatar
I don't think it pulls fuel, I think it pulls the throttle back a little. In that case, it would not be causing the car to run lean. I don't have any facts to support this, just a gut feeling from hitting the TC a lot.
Old 12/26/07, 07:59 AM
Steved's Avatar
I'm pretty sure I saw the fuel pressure drop just as all the bad noises started. I came home and googled "traction control lean" seems It's happen to others.
Think I'm going to pull the center trim panel on the kids stang today and play with the switch.
Old 12/26/07, 09:16 AM
05YellowGT's Avatar
I don't know if it pulls timing or not , but I do remember reading that it uses the anti-lock braking system for at least part of the traction control ...
Old 12/26/07, 09:42 AM
Steved's Avatar
Well back to the mod..
Switch is a momentary contact signal wire.
Pin 1 - Blk - Ground
Pin 3 - Yellow - Wake on start +12v
Pin 7 - White/Pink - TCS Computer signal wire (Change to next step)
Ordered a Timer:
http://www.altronix.com/index.php?pid=2&model_num=6062
Has more features than I need but for 20 bucks, what the heck....
We'll see what happens...
Old 12/26/07, 10:25 AM
Five Oh Brian's Avatar
Per Ford: T/C pulls timing first, then pulls fuel second, then applies brakes last.
Old 12/26/07, 10:31 AM
n00bstang's Avatar
does that mean better mpg with TC on?
Old 12/26/07, 12:59 PM
05YellowGT's Avatar
Be sure to let us know how this goes , and do a TacoBill style write up ...
Old 12/26/07, 02:59 PM
Pwny's Avatar
Wow. Thats like car suicide.
Old 12/26/07, 04:55 PM
Shelby10''s Avatar
I believe you are correct sir
Old 12/26/07, 04:56 PM
Larmo's Avatar
Please keep us informed...
Old 12/26/07, 05:28 PM
gloryboy's Avatar
I didn't know it pulled fuel either. I had mine turned off after the s/c origionally went in, but after switching intake i had it turned back on. Well i can tell you that it definitly applies the brakes. If you decide to roast the tires, dont forget to turn off the tc. Rear brakes come on and the stock clutch doesn't like beeing the middle man between the rear brakes and a sc'd engine ...........Clutch was chattering bad for a few days but seems to have smoothed out...for now..........cant wait to get the tc turned off again!
Old 12/26/07, 06:14 PM
Pwny's Avatar
Did your engine go boom?
Old 12/26/07, 06:40 PM
gloryboy's Avatar
Engine is fine, but the clutch and rear brakes werent too happy.......it was a long cool down!
Old 12/26/07, 08:56 PM
Steved's Avatar
Will do, just waiting on the timer.
Are there any circuits that are live only with engine on? The only one I could find is the brake pedal feedback position switch.... weird...
The car I'm putting the mod in is my wife's car OZMA.... ( Princess of OZ )
The family:
Attached Thumbnails Traction Control Button-ozma4.jpg   Traction Control Button-gtcsbra2.jpg
Old 12/27/07, 05:51 AM
05YellowGT's Avatar
There was a thread where they showed two of the fuses in the engine compartment. One of them was live when the key was on and the other one only when the engine was on. I think I have the picture from the thread at home , I'll take a look ...
Old 12/27/07, 03:27 PM
No, TC only intervenes (pulling spark and fuel) when tirespin is detected. It does not pull spark and fuel for normal cruising, so mpg is unaffected.
Quick Reply: Traction Control Button
