Traction Control Active
Old Feb 21, 2005 | 05:17 PM
Preacher's Avatar
I posted this before but couldn't get an answer. When I accelerate hard in first and 2nd with traction control active (like on a snowy road) I hear a loud rattle from the front left of the car. This happens only when trying to give more gas with the message center stating "Traction Control Active". I read some saying that TCS was perfectly silent. Is that a defect?
Also today when I left from work I got a flashing check engine light and I could feel he car was rumbling more than unusual. I drove for ten minutes on the highway and the lflashing light went off and the engine sounded normal again. I read this mean a possibly serious engine failure. I think maybe the engine was cold. Or maybe the air intake was obstructed by snow. What do you think...
Martin's getting worried...
Old Feb 21, 2005 | 05:22 PM
Mustang69-05's Avatar
I would just take it to the dealer. It could be a number of things. When you take it in just be very discriptive. They should be able to figure it out.
Old Feb 21, 2005 | 08:47 PM
MJC302's Avatar
The only thing your left front wheel should be doing when the 'traction control' is on is pulsing the brake of that wheel. The power cylinder of the anti-lock brake system is in the left front(driver side). The dealer will probably check this. Maybe the mounting is loose or there is something else loose, since the pulsing mechanism is near the airbox. Otherwise the gap between your ALB sensor for the left wheel and the teeth of the ALB disc that is part of your caliper has something messing up the correct thickness of the gap. Good luck!! :bang:
Old Feb 21, 2005 | 09:38 PM
woody1's Avatar
B) Ditto others comment on traction control. See your dealer.
On your CEL, I had this happen on ours, turned out to be the gas cap was not properly tightened after my last fueling. Dealer confirmed CEL/Gas Cap issue when they scanned the system.
Old Feb 22, 2005 | 06:44 AM
lodom's Avatar
It may have been me posting that the TCS should be silent, and I may have incorrectly responded to your post. If it is active (light is on), you will feel the ABS working and the system will make various noises. I doubt there is anything wrong with your ABS.
There are some TSB's on check engine lights, and depending on when your car was built, it may need an update to get rid of them. Of course, it may be something else and your car should have stored the code in the computer if you take it in. I'd have the dealer check the car codes out and try to get the latest updates while they are at it.
Old Feb 22, 2005 | 08:31 AM
Preacher's Avatar
Thanks guys. This is all very helpful information. On previous topics about TCS there was a debate about wether or not the TCS were controlling the brakes or only reducing the throttle. My noise could very well come from the ABS (thanks Mark for the info about the location of the power cylinder of ABS. That would explain why I hear a noise there). I'm still not sure if the rattling is normal or not but I'll have it checked.
As for my check engine light, listen to this. The same day I got the flasing check engine light, one of my coworker had troubles starting its old car. He gave the engine more gas and his muffler litteraly exploded! It seems it may have been obstructed by something. He was parked in the same direction as my car and the weather was very windy and snowy. I think my exhaust may have been obstructed by the snow too... With dual exhaust I admit It would be a bit surprising but dont' you think it's a strange coincidence?
Old Feb 22, 2005 | 01:40 PM
S197 GT's Avatar
3rd Times A Charm
Definately get any noises checked out, and don't let the dealer push you around.
Old Feb 23, 2005 | 12:43 AM
zinn's Avatar
I was watching a show that was seeing if sticking fruit or vegetables in a cars exhaust would do anything. All it did was propel fruit and vegetables out the pipe. I suspect the car next to you had a backfire and a very old exhaust.
papayote
Ecoboost
Feb 21, 2017 11:16 PM
yabutt
Oct 23, 2015 01:05 PM
Sep 8, 2015 10:45 AM
