Track tested an auto with 4.30 and predator today
Old Mar 6, 2005 | 06:07 PM
Black Magic's Avatar
Best stock et before today at 3685 pounds was 13.83 @ 98.21mph for my automatic. Today ran stock tires - trap and a 4.30 gear. Then down loaded a 87 diablo tune.
Results stock: 2.10 60' 5.82 330' 8.90 1/8th @ 80.24 13.83 @ 98.21 Old times.
Added 4.30 gear today results:2.04 5.73 8.80 @ 79.89 13.67 @ 100.93
Today added 87 diablo tune results: 2.05 8.74 80.81 13.54 @ 103.25
I learned that the converter is tight to get a good 60'. A 4.30 gear flys through 1-2-and 3rd gears before the 330' mark. RPM at 1320' is 5800 rpm. It makes 4th gear work hard but IMO waste torque and usage of the first 3 gears. Anything above a 2000 launch smokes the tires. I left at 2000 and let it roll a few feet then eased into it quickly.
I was happy to see 103.25 mph but the et does not match the mph due to converter. I ran 22.44 mph out the back door as good as most sticks.
So auto's will have a tough time to match the sticks based on the converter IMO.
I was thinking the gear alone would help the car more but not so far with my mods.
RPM at 60mph is 2450 rpm on way home.
Hope this helps some for the auto's.
Old Mar 6, 2005 | 06:59 PM
Purple Hayz's Avatar
those are still decent gains and decent results. Thanks for posting them. :drive:
Old Mar 6, 2005 | 07:15 PM
S197 GT's Avatar
3rd Times A Charm
Why the 4:30's as opposed to the 4:10's if you din't mind? I don't know about gears and I was looking to get some 4:10's. Thanks for your advice in advance.
Old Mar 6, 2005 | 07:57 PM
I wanted to test a theory about gears in an automatic. I knew that most sticks would go with a 4.10 from 3.55. So to better equal out things(auto vs stick for my own peace of mind) I went with the 4.30. Mostly to see if the MPH gap could be closed between a stock 3.55 stick and a stock 3.31 auto. I think you will note most stock sticks ave 101 to 103 mph in the 1/4. Now we know a 4.30 gear in a auto will put you over 100 mph almost 101. I plan to go back later and try a 4.10 to make better use of the first 3 gears. After I try some other mods. You can also see that the stock converter holds these back. I want to add I have nothing but praise for the sticks :worship: . It's my own little project trying to make this auto a little faster. 4.10's would be a good deal for an auto IMO. Good Luck.
Old Mar 7, 2005 | 08:08 AM
swingle007's Avatar
Good info Scott....Glad to see you're still tiinkering bro...
John
Old Mar 7, 2005 | 08:50 AM
acadian's Avatar
Good idea testing the 4.30's but are you planning on switching those to 4.10's? That's what I will be putting in next. That should help you out for sure.
DarrenGT
Aug 28, 2015 10:01 AM
Evil_Capri
Aug 27, 2015 01:08 PM
DarrenGT
Aug 19, 2015 08:22 AM
Jul 30, 2015 06:47 AM
Burnhaven
V6 Performance Mods
Jul 23, 2015 11:57 AM
