Torque specs for struts/shocks?
Hey everyone,
Long time lurker, first time poster with a question I know this crowd can answer easily.
I'm installing my new Steeda Ultralite springs on Saturday, and realized I dont know the torque specifications for the spindle bolts, strut tower bolts, lower shock bolts, swaybars, etc. Could someone please direct me to a source for this info, or post the numbers if possible? Thanks in advance.
Torque Specifications
Description Nm lb-ft lb-in
Brake caliper bracket bolts 133 98 —
Dust shield bolts 20 15 —
Wheel spindle pinch nut 103 76 —
Lower control arm forward bolt 175 129 —
Lower control arm rearward nuts 175 129 —
Heat shield bolts 10 — 89
Brake line bracket bolt 20 15 —
Strut upper nut 62 46 —
Strut-to-spindle bolts 200 148 —
Strut-to-body nuts 35 26 —
Wheel hub retainer nut 300 221 —
Stabilizer bar bracket nuts 70 52 —
Stabilizer bar link nuts 115 85 --
Anti-lock brake sensor bolt 6 — 53
Outer tie-rod end nuts 80 59 —
Steering gear mounting bolts 115 85 —
Sorry, the table is a mess, can't copy and paste correctly.
Sweet! Thanks man
Just to make sure I'm reading the table right, the first number is for Nm, second for lb/ft, third for lb/in,and a dash means no spec?
So the Heat Shield bolts would be 10 Nm, 89 lb/in, with no lb/ft spec, and the Strut to Spindle bolts would be 200 Nm, 148 lb/ft, with no lb/in spec.
Sounds about right to me. Thanks again Craig, this board is great!
