Torque Specs
Old Apr 19, 2007 | 12:48 PM
TKEUofM's Avatar
Torque Specs
Anyone know where I can find torque specs for BMR and Eibach suspension parts? I can't find my original paperwork.
I getting some clunking noises while backing out of the driveway and over certain bumps in the road. Got a feeling that the Michigan roads are taking its toll on the suspension.
I have the following:
BMR Lower Control Arms
BMR Adj Panhard bar
BMR Panhard bar brace
BMR Lower control arm relocation brackets
BMR Strut tower brace
Eibach Front and Rear sway bars.
Old Apr 19, 2007 | 02:22 PM
06GT4RAD's Avatar
Did you replace the stock suspension bolts yet? They are one time use torque to yield bolts and are suppose to be replaced when removed.
Here is a link with the specs try that first and see what happens.
http://www.2005stang.com/gallery/alb...suspention.pdf
http://www.2005stang.com/gallery/alb...ded%20view.pdf
Richard
Old Apr 19, 2007 | 02:34 PM
TKEUofM's Avatar
Richard
I'm pretty sure that I used the new bolts that came with all of the new parts. Thanks for the info.
Old Apr 19, 2007 | 07:04 PM
06GT4RAD's Avatar
Most of those parts you mentioned Do NOT come with all the bolts, they make you use some of the stock bolts and if that is the case you should buy new ones from Ford.
Richard
Old Apr 19, 2007 | 07:56 PM
RadBOSS's Avatar
Either way, follow the Ford torque spec's ... unless BMR is calling for more for their special bolts.
GrabberBlue310
2012-2013 BOSS 302
Sep 17, 2015 08:21 AM
MustangGTCS13
Sep 17, 2015 07:38 AM
Allen Hanback
Sep 14, 2015 04:37 PM
SMOKE46
Sep 6, 2015 09:40 PM
