Torque Specs?
Old Apr 7, 2007 | 02:06 PM
Rondosa's Avatar
Meet Krissy, Our Star Racer
Torque Specs?
Help - where can i find a list of all the torque specs for the car, specifially looking for brakes (banjo bolt etc).
tia
kristina
Old Apr 7, 2007 | 02:16 PM
Rondosa's Avatar
Never mind - found it through alldatapro.com - 70nm/52lb/ft
Old Apr 7, 2007 | 02:47 PM
scramblr's Avatar
Be careful if you're using aftermarket lines and washers. 52lbs will crack washers, 35lbs will work better. If you're using OEM stuff then all is good.
Old Apr 7, 2007 | 03:47 PM
DynamicmustangGT's Avatar
The torque for all the aftermarket stuff should be in the instructions anyway. I highly recommend what they recommend so that you don't under/ over tighten
Old Apr 8, 2007 | 12:39 AM
scramblr's Avatar
FYI. Earl's SS lines have the OEM specs for their banjo bolts. It will crush and crack their washers. They are supposed to be changing their instructions, but haven't yet that I know of. Couple of folks have had issues with the washers cracking based on OEM specs.
GrabberBlue310
2012-2013 BOSS 302
Sep 17, 2015 08:21 AM
MustangGTCS13
Sep 17, 2015 07:38 AM
Allen Hanback
Sep 14, 2015 04:37 PM
SMOKE46
Sep 6, 2015 09:40 PM
